Old 12-09-2018, 10:55 AM   #1
PANDEMIC   PANDEMIC is offline
need help
my taotao rhino 250 won't start I can only assume it is the carb when I spray carb cleaner in the spark plug it will fire for a second.
I use only ethanol free fuel. but did leave gas in the bowl for 3 months.
My daughter's apollo blazer 9 was hard to start but I was able to get it started. But it then started leaking gas out the hose that runs to the bottom of the machine. I am again assuming the float on the carb is stuck.
Both machines have less than 10 hours on them. I installed hour meters before they were ever started.
for my help can someone please tell me what ngk spark plug goes in the rhino.
Thanks alot
Old 12-09-2018, 12:47 PM   #2
I think I found it.
Rhino 250 - NGK DR8EA
Apollo Blazer 9 - NGK C7HSA
Old 12-09-2018, 12:48 PM   #3
Now if I can open the carb can I swap the jets or do I need a whole new carb still?
Old 12-09-2018, 12:53 PM   #4
Mudflap   Mudflap is offline
Probably just clogged jets. Just clean them out.
Old 12-09-2018, 03:42 PM   #5
ok cleaned carb. she fired up but I swear there was nothing in the carb no junk like I see when cleaning carbs that people use ethanol fuel in.
still thinking it is time to upgrade carb.
Old 12-09-2018, 03:53 PM   #6
Originally Posted by PANDEMIC View Post
I think I found it.
so far both machines are running fine with the listed NGK Plugs
Old 12-09-2018, 04:59 PM   #7
cycle   cycle is offline
I gather you have already altered the stock carb to gain access to the jets.
I went ahead and upgraded the carb after the maiden voyage. I probably could have changed the needle and jets in the stocker but the upgraded carb was cheap enough so I figured why bother.
Mikuni VM26 30mm Carb Carburetor... https://www.amazon.com/dp/B07CN36W65?ref=yo_pop_ma_swf
I swapped the cap as the stock cable end will not seat correctly in the mikuni cap. I also swapped the choke lever, dropped the needle to the 4th slot and put in a 110 main jet.
Old 12-09-2018, 05:37 PM   #8
Is she running well for you in cold temps? I plan on using the rhino to tow my Eskimo flip shanty. Thanks for the info on your setup also
Old 12-09-2018, 05:45 PM   #9
yes..running great. the carb mod provides so much more adjustability.
