good chain adjustment
at the 49 second mark,,, he is talking about the inside lock nuts... I tell everyone to throw them away... remove adjusting eyebolts.. 1 at a time... throw the inside locknut away and this also lets you adjust the adjustor with out stripping it,,, see video .. and adjust your axle spread ( front to rear .. within 1/2 inch on both side... 1/2 deflection in chain
I did just that after I stripped the adjuster.
locknut
yes I did not know why they put it on there and after about 5 years of selling them... I finally figured it.. that back one is for moving the axle forward.... it is better to throw it away.. and it you have to move it forward use 1inch ratcheting strap on front A arm and over the rear axle and use that to pull it forward( after you have all the nuts loose) .
