300cc Utility?
Anyone seen or ridden some of the newer 300 utility quads? They state that they are full size. Are they as big as a 500 Polaris, etc?
Thanks! |
Hello,
What brand were you asking about. I have tested a few and found that they are a little smaller. I did find that the 400-600cc chinese atvs matched up well against the big four. |
The kymco ones are taiwan built, but they seem to be almost the same size.
Allen
What about Lifan's 400ST?
300 4x4
I bought a buyang 300 4x4. I have ridden several diffrent brands of atv. Polaris,kawasaki, and others. I like the ride and size of the 300 better than some of the bigger japanese models. Suspension feels like a cadilac instead of a 3/4 ton pickup. Mine is the same size as the 600 kawa, maybe a little longer. I also have a 85 yamaha vmax, when I want to go fast. I think the 300 is not over or under powered for an atv. Wouldnt want to have to tow a 5000 lb. boat with it though!!!
roy ![]() |
WELCOME Roy!!
Where did you get your Buyang? How much do those cost? BTW - VMax's are nasty! |
buyang 300 4x4
heh Savage, well I live out in the middle of the mohave desert, literally. I am lucky to have a land line now, so I ordered it over the net from rightwayatv.com for about 3488.00 delivered to my door. I looked at the local japanese models and just didn't like what I was seeing for more than twice the money. It is a shaft drive, water cooled, 4 wheel disc. There are about a dozen diffrent net distributors for this brand. I chose this one due to the good BBB review of this distributor. This guy actually has 3 or 4 net sites. I have had couple tec problems and the dealer has stood good with advice and parts. He shipped me the parts for what I thought was wrong. Problem solved and runs like a top except for the elevation thing. I will buy from him again. So when you pass through the mohave desert and see a trail of dust it will probly be me on my BMW. (Buyang Motor Works)
Buyang
Hi I know this is really old. I picked up brand new buyang 300. The problem is there missing the upper electronics. CDI. IGNITION SWITCH. KILL SWITCH. cannot find parts.
#9 | |
![]() Standard 1 as: https://unitedexpressdist.3dcartstor.../CDI-0068d.JPG Quad/ ATV version had some speed limits: https://www.aliexpress.com/item/32900354720.html Once confirm is which, we can help to find somthing works.
#10 |
So I’m new here and new to this discussion. Just bought a new Linhai 300 4x4 for our small farm to help haul feed etc. Love it so far. Any advice or anything that need to watch our for?
#11 |
Don't let the fuel sit in the carb. suggest to drain the carb. alchohol in the fuel will clog the carb if you don't drain the float bowl.
2007 4x4 300 buyang atv <br />2009 4x4 300 Buyang atv<br />1985 yamaha v-max/2009 fuel inj Yamaha Rhino |
