11-22-2018, 10:17 PM | #1 |
DIY tire change?
What special tools do I need? Is it a big pita to do making it worth while getting them done.no
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
11-22-2018, 10:49 PM | #2 |
Tire spoons, preferably three. Valve core remover. If you are doing tires with tubes, valve puller and talcum powder. Spray bottle with soapy water no matter what tires you’re doing. Rim protector if you are doing aluminum rims. Air compressor. Upper body strength.
11-22-2018, 11:08 PM | #3 |
Thinking about buying another pair of rims and was wondering if grom rims are the same? I haven't been able to find any used rims for these China bikes but have found several off groms
11-23-2018, 12:48 AM | #4 |
2 8' tyre levers and a bottle of dish wash...
If you need levers longer than 8"/200mm you are doing something wrong.. the trick is to make sure the other side of the tyre to where you are working is pushed down into the rim well that gives more free tyre on the part you are working.. I do 4 to 6 tyre changes a year and have done for 20 odd years that is all I have ever used... One of those things where pactice is needed... your first few will be a real pain in the ass.. I find the hard bit is getting the wheel out and back in the bike.. ..
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 11-23-2018 at 01:42 AM. |
11-23-2018, 01:09 AM | #5 |
Thanks I will probably give it a try and if I cant get it done, I will take them to a shop.
11-23-2018, 06:35 AM | #6 |
I installed two Maxxis tires on my Hellcat using a spoon kit I bought on Amazon, I got it done but it was a real pain. It came with rim protectors but the spoons slipped off a few times and I mananaged to put a few scratches on my rim.
I initially tried to do the zip tie method. Like this guy. He makes it look easy. I think it would have worked for me but I couldnt find a good anchor point and I only had a couple of flimsy 2x4's. It did work good for breaking the beads though |
11-23-2018, 12:44 PM | #7 |
What about the cheap Harbor Freight manual tire changers? Anyone tried one? Probably waste of money, I'm guessing. Don't have a link.
11-23-2018, 05:43 PM | #8 | |
I have one and it works well. I also have a no scuff tool and it works well as well. http://no-scufftiretool.com/ |
11-23-2018, 08:30 PM | #9 | |
looks easy.. Now lets see him do that with tubed tyres.. ..
11-23-2018, 09:15 PM | #10 | |
11-24-2018, 11:17 AM | #11 | |
Keep us posted on what you end up doing.
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
11-24-2018, 11:20 AM | #12 |
That is the moto tire changer on top of the car tire changer. One or the other works. I've seen pic posted in other forums of small wheels being on there. The clamps can pull in tight on the moto tire changer. Mine is the first gen version. I don't know about the newer versions. HF is up to three of four renditions of the original tire changers. If I can get out today, I'll measure it and see.
11-24-2018, 11:16 PM | #13 |
Dual-sport tires have relatively soft sidewalls and are pretty easy to change.
11-26-2018, 08:58 AM | #14 |
I do the tire changes with the short irons and soapy water and a couple 2x4s under the wheel. I thought about getting the HF tire changer but don't do enough tire changes to justify the purchase.
11-26-2018, 09:46 AM | #15 |
I measured my tire changer. Mine will go down to an 8-inch rim. However, my version is an older one from back before HF discontinued them for several years. I don't know if the two newer versions will work. You can measure one in the store and see. You need 5.5 to 6 inches between the rim mount holes and the center.
