11-05-2018, 11:28 PM | #1 |
tt250 rear end failure
this is what happens when the rear sprocket bolts either come loose or come stripped form the factory ... new rear rim ... new swing arm and chain adjuster.
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
11-06-2018, 07:38 AM | #2 |
yikes. I bet that was terrifying. glad it was not worse.
11-06-2018, 10:28 AM | #3 |
Was it considered to be warranty?
11-06-2018, 11:10 AM | #4 |
Hopefully you didn't get tossed from the bike and hurt from that insane failure... could have easily locked up or twisted funny and "whip/throw" you off the bike
11-06-2018, 12:04 PM | #5 |
Ouch. At what mileage did this happen? Had you done any work to the bike, such as changing sprocket?
2018 TT 250 2016 RX3 1979 CB750K |
11-06-2018, 12:27 PM | #6 |
the failure
so i was going about 45mph when this happenned thankfully one bolt held in and i was not tossed from the bike. i had csc put the 47 tooth sprocket on when i bought the bike and it happened at about 3000miles on the odo there was no lock tight on the bolts and they vibrated out im guessing and or they were cross treaded by the guys at csc simple mistake im not mad it gave me some quality time tinkering to fix it and it was all covered under warranty so it was basically a free fix i did however have to send back the old rim. only issue i ran into with the replacement parts is the bolts they sent to put the sprocket on the new rim were too long so i had to go to the hardware store and get some m10 by 1.25 studs and cut those because they also were a hair too long.... the ones csc sent wernt the best quality for the application anyways and id rather not have this happen again so some good bolts and lock tight should fix it.
11-06-2018, 12:55 PM | #7 |
It's been my experience with these that the metal in the hub is very gummy. When I changed my TT250 sprocket, I had to be super careful pulling them, then I ran a tap down them to clean them out. They had a white type of locktite in the holes and the threads weren't the prettiest once extracted. I used my own bolts and blue locktite upon reassembly. I've now been inspired to check them.
11-06-2018, 06:36 PM | #8 |
MegaDan put a thread together that lists the Honda parts to fix that problem. It's been a recurring problem with some of the other CB's as well.
11-06-2018, 08:40 PM | #9 |
what's the title of the thread. or better yet can you tag a link
11-07-2018, 10:44 AM | #10 |
Dan's thread: http://www.chinariders.net/showthrea...=hawk+sprocket
11-07-2018, 01:34 PM | #11 | |
Read the thread. Sure miss Hertz around here. :-(
11-07-2018, 08:20 PM | #13 |
Getting off topic, but his birthday reminder is coming up on FB for Nov. 11th since we became friends through the FB group, China Bikes North America. :(
11-07-2018, 08:44 PM | #14 |
The rubber bushes in the rear hub?
Several solutions possible n I was thinking to offer these in my online shop Some have a bush no thread n a bolt they holds sprocket etc maybe Hawk 250 Some have a bolt into the bush maybe CSC250 Some have a metal insert and bolt into it no Cush drive but less trouble Thoughts? |
11-08-2018, 12:18 AM | #15 |
dose the hawk motor have a cushing unit in the clutch basket...
springs between the alloy basket & backing gear.. my XT660 has both in the basket and rear hub..but the TTR250 has no cush drive at all... most 250cc bikes don't need a cush unit as the engine braking effect between power strokes is not big enough to create a lot of back lash in the drive train when you come off the throttle... ..
