Old 11-01-2018, 07:48 PM   #1
Whisky   Whisky is offline
Whisky's Avatar
Upgrade front shocks
Are the Grom front forks the same size as the vaders? What options "if any" is there available to improve the shock dampening?
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 11-03-2018, 03:58 PM   #2
1600degrees   1600degrees is offline
I believe the clone forks are slightly different from the grom ones, although it's possible they are interchangeable. You could always try a better shock fluid before swapping them entirely. I will be trying the Amsoil Shock Therapy fluid in my Hellcat shortly. https://www.amsoil.com/shop/by-produ...id/?zo=5178398
Old 11-04-2018, 10:36 AM   #3
Whisky's Avatar
Yeah I know about changing the shock oil with some real stuff, I was just thinking it would be easier to change the internals rather than having to remove the forks completely. Got to do something as they suck bad imo.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-05-2018, 12:06 AM   #4
No. they won't fit.
Old 11-05-2018, 12:10 AM   #5
You could try the Grom 15$ fork mod thing with the washers.
Let use know what you do.
Old 11-05-2018, 05:20 AM   #6
Whisky's Avatar
Is that a kit or is it just adding a washer? I did see the video but I didn't see if it said it was a kit or not.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-07-2018, 02:51 PM   #7
wlfpck   wlfpck is offline
cbrfxr67 took his front shocks apart already. Won't be able to do the grom fork mod the exact same way.
http://www.chinariders.net/showthrea...t=21622&page=3
The issue is how that rod is screwed into the cap. You could add a couple washer and still thread it in, but you don't really gain much from that. Maybe with a threaded extension? But you'd have to spend some time at Ace hardware to find something that will fit.
cbrfxr67 replaced the fork oil with thicker stuff and that helps out a lot. This is also what a lot of Grom people do as well.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 11-07-2018, 09:29 PM   #8
The stock " fork oil" should hardly be called that , and it's quite common for the forks to be underfilled from the factory on top of that . Switching out to a quality 15w forkoil really will do wonders ,use 225ml to 250ml per side .
If you still feel like you need a bit more stiffness, I used a $99 front fork preload cap set from SlingShot Racing for the Grom, they fit Vaders fine ,there is an install video available on YouTube but it's very easy ,between those preload adjusters and the better fork oil I have been fine .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
