Old 10-24-2018, 09:03 AM   #1
Du_you_copy?   Du_you_copy? is offline
Hi from NY - SSR Razkull Rider
Greetings from New York!
Wanted to say hey & do a mods/upgrades/parts list for my 2017 "DUCOPY" SSR Razkull 125.
Advice for anyone with a Razkull or a Venom / Ice Bear clone copy:
TOSS the stock carburetor ASAP. Go over all engine bolts w/ Loctite or stronger replacements first, then immediately swap the carb. My stock PZ19 carb literally blew off at the bowl while cruising on the highway @ 50mph.
Bought it barely used w/ about 17 mi. and put on about 1300 mi. + in the past 4 months. The monster is running a little rich as I'm still tuning but, overall it's been a blast & quite reliable for such an inexpensive street bike. It gets so much more attention than any Grom on the street.
- Mikuni VM22 Upgrade Kit
(Chinese clone - the carb, intake manifold & gaskets were all pretty good quality and have been strong for over a month now!)
http://a.co/d/27cTF4o
- # 125 Main Jet
(these were the only jets that fit this carby, various sizes in kit)
http://a.co/d/h6Bojpi
- # 40 Pilot Jet
(this particular carby took the Keihin 3J pilots - stock carb came w/ a poorly drilled #38 Keihin 3j slow jet, I might swap back to a #38 but a higher quality one from jetsRus)
https://jetsrus.com/a_jets_by_carbur...n_3J_slow.html
- 38mm K&N style Air Filter + inline fuel filters
http://a.co/d/5RaT0ax
- Red 135 degree silicone elbow
(connects air filter to carby without pushing on plastics)
https://www.pegasusautoracing.com/pr...sp?RecID=11551
- Clear fuel line replacement
http://a.co/d/7g48ifu
- NGK CR6E plugs
(6965)
http://a.co/d/6bibMcm
- UNI crankcase breather filter
http://a.co/d/iOFaAC1
- SC Project - Grom Full Exhaust
(Super loud & throaty, installed fairly easy. Decent quality for the price, carbon wrap started to pull up a little after a month. Performance was still great, but it's just a little too loud IMHO. Muffler didn't come with a dB killer... prob buying a quieter muffler in the near future.)
https://ebay.us/wlCVIP
- Jrl Exhaust crush gasket for header pipe to engine exhaust outlet
(fits perfect)
http://a.co/d/1lvbgWx
- 16T Front sprocket
(+1 in the front, def added 3-5mph on my top end without sacrificing acceleration. First gear is a slight bit longer & more usable now)
http://a.co/d/iL7Qou0
- 34T Rear sprocket
(stock gear size, just better quality upgrade)
https://www.whygostock.com/ssr-razku...rear-sprocket/
- RK Racing 428 heavy-duty Gold Chain
(110 links but only needed 108 w/ this particular gearing, looks amazing)
http://a.co/d/bW698fF
- Michelin City Grip tires
(120/70-12 , very grippy - now the bike sticks to pavement like crazy & no more sliding around in wet weather...highly recommend these tires!)
http://a.co/d/gu6eFF1
- MZS Shorty Brake & Clutch Levers
(for a Grommy but were a perfect fit. Great build quality. Definitely smoother shifts & much easier to find neutral over the stock levers)
http://a.co/d/dqr2pu9
- MZS Bar End Mirrors
(Poor build quality, eventually both flew off of bike randomly, mounts weren't strong nor fit well)
http://a.co/d/c4JmWh5
- Kawell Universal Bar End Mirrors
(Much better quality than MZS's, but not as cool, they def have a better sight range as well)
http://a.co/d/9T6SrAl
- Cougar Motor H11 LED Fog Light Bulbs
(slightly better hi/lo beams vs. stock)
http://a.co/d/iTdhb7B
- Beamtech H11 LED Head Light Bulbs
(Much brighter than Cougar's & significantly better than stock. Couldn't fit into the hi beam and mount the headlight assembly back on. Running 2 Cougar bulbs for now.)
http://a.co/d/eYV99ku
- Vagabond Motorsports Fender Eliminator kit
(for the 17+ SSR Razkull... it's a little pricey, but worth every penny...super easy & clean install)
http://a.co/d/0Hddd6d
- USB Charger
http://a.co/d/iHnF1s4
- Roam cell phone mount
(so far so good!)
http://a.co/d/0UmaOti
- uxCell water-proof Horn upgrade
(much louder than stock, simple swap... but, the sc project exhaust is still the loudest thing on the bike hehe)
http://a.co/d/2aQbCAF
- Stop-Alert FastFlash LED Brake Light strobe
(def makes you more noticeable when braking)
http://a.co/d/9sQjLdm
Some pics to follow!
Old 10-29-2018, 12:02 PM   #2
wlfpck   wlfpck is offline
I like that silicone tube at the end of the carb that let you point it upward. Have you tried a 17T? I'm running 17T front and still have no issues pegging redline in 4th... but that's why the ZS190 goes in when I have time.
You're running 125/40 for your jets. Where's your needle located? I think this would be a good starting point for anyone that is swapping their carb. New York city is at 33' elevation. You said you were going back to 38 when you get a good quality one. Are you bogging at all with the 40?
Exhaust for the SSR razkull is different than the icebear little monster and fuerza. SSR has the straight down vertical exhaust port like the grom. The vader, fuerza, little monster, hellcat are all angled like the CRF50 engine.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 10-06-2022, 11:35 AM   #3
tinyvroomvroom   tinyvroomvroom is offline
thank you this was very helpful and direct. I am working on getting my 125 razskull running right. Do you have any pictures of your carb setup? Also, did you run into any issues with disconnecting the choke cable?
Thanks!
