Old 10-13-2018, 07:40 PM   #1
Whisky   Whisky is offline
Whisky's Avatar
New exhaust
Wanted to try something else with a different tone. I like this one better.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 10-14-2018, 01:22 AM   #2
Looks great, what exhaust is it. Hows it sound, loud?
Old 10-14-2018, 02:52 AM   #3
Whisky's Avatar
It's this one. I left the baffle in so it's not very loud now. With out the baffle it's fairly loud.
https://www.amazon.com/Honda-Aodonly...499727&sr=8-13
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-14-2018, 10:56 PM   #4
Vx21rsjohn   Vx21rsjohn is offline
I have the same exhaust just different color. How do you take the baffle out?
Old 10-15-2018, 12:46 AM   #5
wheelbender6's Avatar
Looks great on the lil Monster.
Old 10-15-2018, 01:50 AM   #6
Whisky's Avatar
I'm not sure but I think it's on the end where it connects onto the pipe. I didn't look into it when installing as I wanted something a little quieter then the exhaust I had on it before.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-18-2018, 02:46 AM   #7
scoot newb   scoot newb is offline
scoot newb's Avatar
Looks sick! Were you able to resolve the carb issue?
Old 10-18-2018, 05:35 AM   #8
Liamsdad   Liamsdad is offline
Liamsdad's Avatar
Will this bolt right up to a Hellcat? Been through 2 exhausts and neither fit.
Old 10-18-2018, 02:07 PM   #9
Whisky's Avatar
Yes finally, what a headache that was. I ended up using #100 jet after trying #95-125. My high/no idle issue ended up being a simple fix by adjusting idle cable on the handlebars first then setting idle on carb. Runs great now, starts right up.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-18-2018, 02:14 PM   #10
Whisky's Avatar
No it wont, you need to heat up and bend the pipe in a couple placed. Here's a link of exhaust that bolt right up with no modifications needed.
https://www.motorkit.com/en/5677-exhaust-onder?p=1
I had this one on first
https://www.ebay.com/itm/Stainless-S...72.m2749.l2649
Here's a pic. This one as a larger diameter then the AR. Its a nice looking exhaust, I just wanted a lower tone then this one has. When/if I get bored with the AR maybe I will go back to this one.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-30-2018, 12:19 AM   #11
@whisky what carb are you running? Haven't been able to ride my bike for a while since I didn't do my mods in order. Bike books and dies at WOT. I knew nothing about carbs before this bike.
Old 10-30-2018, 09:16 AM   #12
Whisky's Avatar
Here's the one I ended up using with a #100 jet. I tried jet#90 all the way up to 125 and the 100 ran the best. What type of cone air filter you are running plays a big part as far as tuning goes. It took me awhile to get it to run right but now it runs great and have no worries of the bike leaving me stranded like it did before.
When I was having running issues I thought it was the carb so I purchased a genuine Mikuni carb for $150. but had the same issue as this $35 one had. It was a jet/tuning issue and the carb listed works great even at the low price.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-30-2018, 12:19 PM   #13
That's the one I've been looking at. Hope it solve the problem I'm having. Been left stranded three times because it wouldn't start again.
Old 10-30-2018, 03:15 PM   #14
Whisky's Avatar
Didn't start but would turn over right? I had to buy a better battery because the one that came with the bike was bad also the sparkplug that it came with was junk as well. Do you have a thread telling about the issues you are having? This forum/members has been a lot of help for sure working through all the issues I have had.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-30-2018, 03:40 PM   #15
I can get it to start no problem, but I can only ride it for short distances. It bogs and dies in the mid to full throttle range.
