09-27-2018, 03:27 PM | #1 |
Solid rims on a hawk, is it possible?
Is it possible to switch to a solid style rim for the hawk? I've tried searching through previous forum posts but can't find anything to match what I'm looking for. Might have been poor word choice on my search.
"Where we're goin....We'll be lucky if they've got roads." -SPC Garcia 2017 "Whats 30 tons of willy pete anyways??" -SGT Nicholes Have a blast both literally and figuratively. |
09-27-2018, 03:34 PM | #2 |
Yes. Some have swapped the stock ones out for Aluminum after bending the stock wheels up.
09-27-2018, 03:37 PM | #3 |
If the rims are made... which I have seen them... and are made in the size you are needing... I really don't see any problems... maybe need to change the speedometer counter.. and cable.. maybe the disc.. but basically it should be a good fit... I have seen some HD's with them... with matching custom paint jobs on them... let us know if you find them... maybe I'll do some searches on custom motorcycle rims/wheels for dirt bikes.. sport bikes and etc...
2006 Roketa DB-07-200 Dual Sport 2007 Monte Carlo SS 5.3 2010 Challenger Hemi 5.7 2004 Isuzu Rodeo 1998 Kia Sportage 4x4 2004 Toyota Tundra 2016 Ford Escape Guitars 1970 Gibson SG mint Condition 2005 Epiphone white Custom SG Les Paul L/New Fender Banjo New Condition BC Rich Bitch - Like New\ 3 Jay Turser SG Good Condition Amps Marshall vs100 Good Condition Acoustic 261 very good condition Boss GT-6 Pedal effects Like New |
09-27-2018, 03:39 PM | #4 |
09-27-2018, 03:46 PM | #5 |
Sorry I used the wrong term, I meant a cast wheel or spokeless. Like you would see on cruisers or most street bikes. I just did a little reading and I may go back on the thought of switching to cast rims. The spoked rim absorbs impacts better and allows for deformation while a cast is more prone to cracking. From what I gathered a cast rim is better for on street performance with less maintenance and generally easy to keep true only due to fragility to localized impact say from a large rock. And a spoked rim is perfect for either just requires more maintenance with keeping true and spoke tension. No being lazy without extra cost here
09-27-2018, 03:50 PM | #6 |
You may want to check and see if the Ninja 250 wheels will mate up. http://www.chinariders.net/showthread.php?p=256567
09-27-2018, 03:52 PM | #7 |
Okay, Gotcha.
09-27-2018, 05:47 PM | #8 |
You can make spoke wheels tubeless by sealing them or buying an expensive system like Tubliss. Just know that once these options are done, tire repairs can be tricky if the tire is on the wheel. It's easier to replace/repair a tube than try a roadside plug on a tubeless conversion. Any little poke too deep with a plug kit, you can lose the seal, and create a big air leak.
09-27-2018, 07:33 PM | #9 |
09-27-2018, 08:00 PM | #10 |
Why ?
09-27-2018, 08:09 PM | #11 | |
