09-26-2018, 11:49 AM | #1 |
Head Light Problem
New out of the crate my Hawks headlight on high beam and small running bulb works fine but on low beam neither burn. So its either the switch or loose wire. Checked the wiring and they appear to be fine. So if its the switch is its going to be replaced or there anything that can be repaired inside the switch.
09-26-2018, 11:56 AM | #2 |
Go through all the connectors and make sure all the pins are locked in place. I had one that wasn't snapped in place.
