Old 09-23-2018, 12:23 PM   #1
Bull   Bull is offline
Mad engine won"t rev up past 1/2 max rpm, valve adjustment, please help
HI,
I am new, looked on this forum but did not see a definite answer, I have a zongshen Bull 250 and one day I was riding and suddenly the bike lost all power and now will not rev more than half of max rpm, it acts like it has a rev limiter so low, and it pops and maybe smokes little black, i replaced the carb so it is not an issue there and then noticed after a day that it has low compression on the kickstarter and there is a sound in the air filter/box when i kick it over so i figured maybe a cam chain skipped a tooth and now the timing is off and intake is maybe open slightly so i am trying to adjust the valves but I cannot find the T mark, there are random letters like SM, and then there are 2 lines that match up with the marking on the crank case but no letter T for Top dead center.. How are the markings on the cam sprocket supposed to sit relative to the T mark for Top dead center? I don"t know anymore where to start and what to do, can someone guide me through valve adjustment and what the clearences should be? I think the engine is CB250, it is air cooled and it is SOHC. THANK YOU!
update: I don"t know if my timing chain has skipped a tooth, so I need to know where the marks on the sprocket are supposed to sit relative to the top dead center. I also noticed that my timing chain is loose on the timing sprocket. Could that be just because I took the head cover of? Is there a way to tighten the timing chain?
File Type: jpg zongshen-bull-250-250-cm3-slika-54296166.jpg (93.9 KB, 315 views)
Last edited by Bull; 09-23-2018 at 01:47 PM. Reason: forgot a detail that might be important.
Old 09-24-2018, 02:15 AM   #2
humanbeing's Avatar
Ur attached image is CG (ohv)
OHC version should be as https://www.njuskalo.hr/enduro-cross...oglas-18069952
Old 09-24-2018, 02:59 AM   #3
pete   pete is offline
pete's Avatar
motor on TDC... the cam sprocket should have a mark/line on each side
that sit inline with the rocker case gasket surface.. no load on the valves..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-24-2018, 05:13 AM   #4
yes, sorry, I have that one, did not notice it was a different engine
Old 09-24-2018, 06:03 AM   #5
Thanks, what are good valve clearences to set?
Old 09-24-2018, 08:43 AM   #6
humanbeing's Avatar
There's 2 type http://zse.cc/productsdetail.aspx?Pr...=368&CateID=43 65.5mm (timing chain 104L) http://zse.cc/productsdetail.aspx?Pr...=370&CateID=46 69mm (timing chain: 102L) of CB250
Honda said in/ex: 0.1mm for their 65.5*62.2
idle, problems, rev, valve adjustment, zongshen 250
