Old 09-23-2018, 09:35 AM   #1
itsnt4me   itsnt4me is offline
itsnt4me's Avatar
Beating A Dead Horse
I know this question has come up before somewhere. I've had a lot of bikes and adjusted a lot of valves and they have always been adjusted stone cold yet the Hawk should be adjusted warm. Is that really true?
Old 09-23-2018, 11:28 AM   #2
Sochin   Sochin is offline
Sochin's Avatar
No, 0.003 on intake and exhaust is the spec cold.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 09-23-2018, 11:39 AM   #3
roundhouse   roundhouse is offline
roundhouse's Avatar
I did mind cold and it worked out great.
Old 09-23-2018, 02:20 PM   #4
itsnt4me's Avatar
Thanks for the info.
Old 09-23-2018, 03:53 PM   #5
cold because thats what the gap is for. when the metal heats up and expands there will be no gap. now i suppose you could do it hot and set them at 0.00 but who wants to work on a hot motor.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-08-2018, 10:05 PM   #6
DUSTANHAWK   DUSTANHAWK is offline
Mines smoking and running hot after valve job, tried to adjust it like 4 times and im at a loss right now. I broke the nut and bold adjusting the exhaust side. Where can i find a new one, gonna start there and go step by step carefully, any one selling the bolt and nut combo? Going around town to try and match it up with new ones. (bolt that rests with nut on valves) Or possibly Any luck on buying someone's top end that i can just bolt on.. looking to spend less than 150$ Thanks if anyone has anything let me know< Dustin
Old 10-08-2018, 10:10 PM   #7
Must have adjusted wrong tdc side< so gonna try again with new hard ware, then go from there, ordering feeler gauges again tonite, good luck with every one's valve job i did mine atg 100 miles and regret it. "Why fix something that is not broken" Because it ran good before, missing those summer days riding around the farm. Iam new here so when i figure out how to start my own thread i will and keep posting about this. sorry guys
Old 10-14-2018, 01:54 AM   #8
motocheez has a good vid on adjusting and how to know which tdc your at. just google him its on youtube
2016 hawk
kaw h1 400 tripple
Old 10-14-2018, 09:22 AM   #9
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Try this to find TDC on the compression stroke. Pull the spark plug and set it aside. Open the magneto port and use the kick starter to rotate to the T mark, at the same time your hand is already plugging the spark plug hole. When the T comes around if you don't feel air hissing out the plug hole then your NOT on TDC compression stroke. Turn it 1 more revolution.
This is fool proof. And you won't have set the valves to the wrong cycle.
Wiggle the rocker arms when your done, they should have the smallest tink -play. Not 1 tight 1 louse.
When the engines humming along you will want a faint ticking sound. You get nervous when you don't hear it a tick anymore.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
