New carb installed but..
It idles around 3000rpm I can take the idle screw completely out and still ides at 3000. The plunger is in correctly and there is plenty of slack in the cable. I put a 115 jet in on the advice of someone on here. No vacuum leaks that I can think off. Any ideas would be appreciated. I did a search already.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
Choke on? You didn't say so gotta ask
BD125-15 |
choke only to start, then off till bike idles.
You might want to try smaller main jets |
nope I look inside end where air filter goes and slide will not go all the way down I don't see any obstructions anywhere
what size 110--105?
Did you adjust the idle mixture screw?
yes seated and out 1.5 turns
I'd open it up and make sure the cable is set right through the top. Maybe it's hung up somehow and not letting the slide go down. Keep fiddling with it, you'll get it.
BD125-15 |
air fuel screw=seated and 1.5 turns out idle screw does nothing I can turn idle higher but not lower
#10 | |
cable is in correctly. I took cable completely off plunger and plunger still does not go down all the way. I do have carb off currently
#11 |
I changed to a 110 jet and idle is still 3k and when I give it some throttle it makes a sucking sound and dies.. going to put the 115 back in as it didn't have the throttle issue
#12 |
Probably will just put stock one back on for now
#13 |
Do you have the slide in the right groove? You might have it reversed. The long narrow groove slides on the pin and the wide groove goes towards the idle screw.
#15 | |
