Old 09-15-2018, 07:35 PM   #1
Sclark1013   Sclark1013 is offline
TT250 Carburetor Swap Recommendations
Would like to swap the stock carburetor that came with the CSC TT250 for a carburetor that will fit without any modifications and that has an easy to access idle screw and an easy to access adjustable pilot screw. Is their such a carburetor available?
The stock carburetor only has an adjustable idle screw and you have to modify the pilot screw, which is on the bottom of the carburetor. To make adjustments, you have to remove the carburetor each time.
Appreciate any thoughts or recommendations!
Old 09-15-2018, 08:50 PM   #2
Digger   Digger is offline
You can buy a kit on ebay that has a longer head on the idle mixture screw you can turn it with a small screwdriver bit with a short piece of hose on it Have my screw set at 3 turns out, 800' elevation. Runs really nice.
Old 09-15-2018, 09:41 PM   #3
Hey Digger thanks! Do you remember what idle mixture screw kit you ordered?
Old 09-15-2018, 10:04 PM   #4
Old 09-15-2018, 10:26 PM   #5
Pz30 carb repair kit it cost $5.10 came from China. The pilot jet was wrong but also had an adjustable needle.
Old 09-15-2018, 10:38 PM   #6
Cravin01   Cravin01 is offline
Cravin01's Avatar
PZ30 pumper carb allllll DAY!!!!!
I'm bias I know but hold on to your britches, Ill post a vid soon of all my one kick cold starts soon on my Bashan Storm. I just got my short cold start pilots in a few days ago but i really don't need them.
MagaDan pointed me towards it.
https://www.ebay.com/p/30mm-Pz30-Acc....c100005.m1851
this is what I bought
https://www.aliexpress.com/item/KEIH...3ad54c4dKFJ2JR
My Video
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 09-16-2018, 10:26 AM   #7
Its_not_a_honda   Its_not_a_honda is offline
I put that very same one on my apollo 250. Changed the main and raised the needle one notch. Awesome carb! My engine is the overhead cam, no counter balance. Cranks with no choke most of the time. The second best mod I have done.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 09-16-2018, 04:03 PM   #8
Great video Cravin01. Like the shirt too! Things are great and getting greater!
Old 09-16-2018, 04:57 PM   #9
sclark1013 that carb kit part# is cg200
Old 09-17-2018, 10:44 AM   #10
Thanks Cravin01. Did you get the pumper carb installed?
Old 09-17-2018, 01:37 PM   #11
Cravin01's Avatar
Oh yeah, I agree with it's not a Honda, one of the best mods on my bike and close to #1.
2017 Bashan Storm
Old 09-17-2018, 07:44 PM   #12
pcspecialist   pcspecialist is offline
Does the choke stay in whatever position you set it on that?
My Video
Old 09-17-2018, 11:41 PM   #13
If you aren't replacing it with a pumper, there is absolutely no point in replacing it at all.
Old 09-18-2018, 04:53 AM   #14
http://www.chinariders.net/showthread.php?t=21082
Old 09-18-2018, 08:37 PM   #15
Cravin01's Avatar
I had to do a little flexing and fidgeting to get it to stay on choke or half choke. now it hold on half good and barely holds on full. The good part is that I don't use any choke now.
Its_not_a_honda,
Somehow I missed that thread but I glad you linked it so I can see what you went through and your right it was a substantial difference in response and ease of starting!
2017 Bashan Storm
