Old 09-13-2018, 08:18 AM   #1
Whisky   Whisky is offline
Whisky's Avatar
Chain adjusters
Is there any chain adjusters that fit these China bikes?
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 09-13-2018, 06:44 PM   #2
Heyas Whisky - Are you looking to replace the internal chain adjusters that fit over the axle inside the swingarm, or the external adjusters ,i.e. the long bolt with the nuts on it for adjusting the chain in the ends of the swingarm with the rectangular plate?
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-14-2018, 10:33 AM   #3
Whisky's Avatar
I want to replace the entire adjuster. I had read that OTB adjusters for the grom fit but had heard they need to be beatin in the swing arm to fit.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-14-2018, 11:49 AM   #4
kirbo7106's Avatar
Just to throw this out there...
Ever think about going with an aftermarket aluminum swing arm? I hear they are better all around. They have actual bearings!
Keep us posted on what you end up doing!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 09-14-2018, 03:44 PM   #5
LeftDfence   LeftDfence is offline
I got the grom ones for my hellcat. They didn't fit. Pounded one in a little and figured I wouldn't be able to adjust anything. Went back to the stock ones.
2017 Taotao Hellcat
2016 Coleman CT200U
Old 09-14-2018, 05:24 PM   #6
kirbo7106's Avatar
That’s not what I wanted to hear! definitely keep us posted on what you end up doing!
Have a great weekend!
Dan-O
Old 09-15-2018, 02:18 AM   #7
Whisky's Avatar
I seen a post somewhere on this forum that they installed OTB brand adjusters but can't seem to find the post it was in. They are 163 bucks so I really don't want to gamble on not fitting. There isn't anything wrong with the stock ones but my biggest worry when riding is things breaking or falling off.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-15-2018, 06:42 AM   #8
scoot newb   scoot newb is offline
scoot newb's Avatar
If they fit the Vader will they fit the Hellcat? http://chinariders.net/showthread.php?t=20651
Old 09-15-2018, 02:12 PM   #9
Whisky's Avatar
That's one of the post about the chain adjusters but there's another one. It's strange how some will fit and some dont. Could the tolerances be that much different.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-15-2018, 03:00 PM   #10
kirbo7106's Avatar
I think there is some variance. Chinese bike manufacturers have a tendency to switch suppliers. Since the Vader and Hellcat are based on the Honda Grom, all the parts should interchange. Unfortunately, there is some variance. I’ve heard of some people having to file the rear swing arm bushings to get it to fit.
I’m going to try and get an aftermarket aluminum swing arm to work on my Hellcat. I’ll post my results.
Enjoy the Ride!
Dan-O
Old 09-15-2018, 09:06 PM   #11
As far as I know , there isn't any guaranteed "no problem it will fit and work " way to address the chain adjuster issue on Vaders / HellKats. The internal OEM Grom chain adjusters are very,very tight in a Clone swingarm so to free them up in order to be able to use some aftermarket external adjusters ,you'd have to have them milled down some ,maybe if you had a big belt sander that might work as well .There does appear to be enough "meat" on them to allow for this and still be functional, strong, and safe.
If you go the replace the entire swingarm and get decent chain adjusters included ,again sometimes they go right on, and sometimes some milling down of the bushings is required which may require once again access to a machine shop or other means
( filing, grinding, sanding, etc) which you may or may not have the tools on hand to do, etc.
This is part of owning a Chinese Grom clone ,all of the Builders use various Suppliers and switch according to price and availability so there is a lot of inherent variation, sometimes you get one Grom parts will go right on, and sometimes you get one that
requires a bit more ingenuity and effort to make stuff work (fit ).
Personally , if the OTB Adjusters are 163.00 US., I'd just swap the entire swingarm out since you can get a better aftermarket aluminum one for about 50$ more ,and it comes with decent , dependable chain adjusters already there . Two I am looking at is a Japanese made Tanaka Swingarm https://www.ebay.com/itm/TANAKA-TRAD...24a9%7Ciid%3A1
and also the "hoop style" Aluminum Swingarm from Thailand : ttps://www.ebay.com/itm/Honda-Grom-Swingarm-Honda-MSX125-2013-2018-Swing-Arm/183250231163?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D20160908105057%26meid%3D07c3c d2645d94610bac9c8b100c600ec%26pid%3D100675%26rk%3D 3%26rkt%3D15%26sd%3D263933485344%26itm%3D183250231 163&_trksid=p2481888.c100675.m4236&_trkparms=pagec i%3A39de6841-b94c-11e8-af78-74dbd180d313|parentrq%3Adfe6c42b1650aa465239ac36ff f724a9|iid%3A1
Either one is about 200$ US including Shipping ,Tanaka parts are real big in Japan and they have a good reputation, but then again the hoop style offers some extra strength for a tad more weight and comes in a range of colors, so I have to make my mind up which I want to go with .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-19-2018, 01:50 PM   #12
wlfpck   wlfpck is offline
Ball out. Go single side swingarm.
https://www.motorkit.com/en/swingarm...-msx-grom.html
No but what RedCrowRides is pretty much spot on. There may be some modifications needed (grinding/cutting) to get things to fit.
My personal opinion is go with something that is going to be durable. Especially if you're going to stunt or thrash on the bike.
The hoop design is going to hopefully be stronger. But it also depends on the aluminum/steel that is used.
Another site to check out is this:
https://www.motorkit.com/en/5087-swi...onda-msx-grom-
The Kepspeed one is popular on the facebook groups and people have been getting engines, parts, etc. delivered to the U.S. with no issues.
I haven't swapped mine out yet. The factory one is ok with me. When I need to change the rear tire... I may swap it out.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
