08-28-2018, 10:41 PM | #1 |
Carb problem
So on my hawk I was having sputtering problems at top speeds. Finally gave in and bought a Mikuni clone carb and a 117.5 main jet. When I installed I was having same problems so I switched to a 115 main, same thing now But got better when my mixture screw was closed. So I went down to a 110 runs really good I can hit 75 on freeway only problem is, my mixture screw is closed. Can anybody please help on why my bike would run best with the mixture screw closed all the way. I think I might have got a bad carb. I’ve done airbox mod, k&n filter, decat the muffler. All before I got my new carb. I do have a leak at my pipe coming out the engin because a bent flange. I was able to straighten it a bit and make it better, but it does still leak slightly when tested with soapy water. I haven’t gone down to a 105 main yet but I think it will be the same thing. I’ve tried everything and always the same bike runs best with mixture screw closed. I know this isn’t right, so does anyone have some suggestions or thoughts. TIA
08-29-2018, 12:28 AM | #2 |
what is the pilot jet youre running? the fuel air screw only adjusts idle fuel mixture
08-29-2018, 01:39 AM | #3 | |
08-29-2018, 07:40 AM | #4 | |
08-29-2018, 08:49 AM | #5 |
Are you referring to the fuel/air screw on the very bottom of your carb (toward the engine side of the carb) or the one on the side that can be adjusted with a Phillips head screwdriver? Regardless, your engine shouldn't idle if either of those screws are turned clockwise all the way in. Ideally your BOTTOM fuel/air screw should be 1.5-2 turns out from bottom, and the side idle adjustment screw should also be backed out a couple of turns but YMMV depending on weather conditions, etc.
Where did you buy your carb? Can you post the link (Amazon, eBay, etc.)? Sometimes debris can get into a new carb and clog a jet so it might be worth grabbing a sewing needle to poke into those jets and using brake cleaner to fully clean out your carb.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
08-29-2018, 11:38 AM | #6 |
Lit Hawk, what elevation are you at?
08-29-2018, 04:12 PM | #7 |
https://www.amazon.com/Mikuni-Carbur...ref=mp_s_a_1_2
Here’s the link to the carb I bought. I’m at 50 feet above sea level. It’s definitly the mixture screw and not the idle screw. I’ve had it a 1.5,2,3 turns out all run ok but when I try to tune the carb idle goes up to highest revs when screw is all the way in. It rides fine except after I’ve ridden it for about 20 min it’ll stall at a light when I go to take off. It’ll also sometimes die when I’ve been riding at top speed and release throttle it’ll shut off. I didn’t know you could pull out the mixture screw and check if tips broken so I’ll check that tonight. If it is broke can I get a replacement? |
08-29-2018, 09:02 PM | #8 |
Are you still running stock spark plug?
08-29-2018, 09:41 PM | #9 |
No I got an iridium spark plug. I checked the mixture screw right now and it looks good. I went down to a 105 and it’s still the same. I can turn the screw in all the way and it sound at it’s best. Took it around and could hit 68 top speed no freeway. I’m stumped I’d like to leave it alone but damn it’s bothering me that something’s not right. Oh yeah and it did shut down on me right now after hitting top speed and releasing throttle. Should I try to return the carb and say it’s faulty?
08-29-2018, 09:58 PM | #10 | |
08-29-2018, 10:11 PM | #11 | |
Whyyyy youuu!! What are your thoughts ARH? Maybe tightened the screw too tight and broke it? It looked good when I removed it. Would an over tightenedmixture screw cause this. I got no luck at all with carbs Only thing I can find online that would cause this is too big a main jet, but I’m already down to a 105 and it’s the same thing. |
08-30-2018, 06:55 AM | #12 |
I know you said, "highest revs when mixture screw is closed," but in tuning the carb you want smoothness in your idle, not just highest revs.
If I were you, I would set the mixture screw at maybe 1 to 1 1/2 turns out from fully seated and ride it. The stalling at a stop I believe is because of your "closed" mixture screw. Do you have the spring, washer and o-ring on your mixture screw, and in that order? If not, it will cause weird things to happen when setting up the carburetor. https://www.bing.com/images/search?v...+mixture+screw Also, make sure there is no trash in the pilot circuit on the carb as said before. How about the float level? Too high of a level and it will be rich as described, check that. The float should be pretty much level with the base of the carb with its tang just touching the top of spring loaded needle while in its seat. You do this visually by turning the carb upside down and the float bowl off to check. https://www.bing.com/images/search?v...uni+carburetor Only other thing that I can think of is a worn main jet needle and seat. It will do the same as you describe, but this is a new carb. I all out of ideas, but have you tried the original carb on it? If you do, don't forget it will need to be mod'd since you have "uncorked" your engine. You know, pull plug on mixture screw so to set, raise needle with a couple of washers, etc... Kirk |
08-30-2018, 08:13 PM | #13 | |
09-26-2018, 10:47 PM | #14 |
Here’s the new mixture screw that I bought fix the Mikuni carb from amazon I linked earlier. Makes adjusting so much better only comes in blue,ships from states only thing is spring o ring and washer came in wrong order so make sure you put in correct order before installing thanks kirkallen143 for the diagram in earlier post. Enjoy
https://www.ebay.com/itm/Air-Fuel-Mi...item285ef36a5e Last edited by Lit Hawk; 09-27-2018 at 10:44 AM. |
09-27-2018, 06:41 AM | #15 |
Thanks for the info. That will help many of us.
