13t front - 33t rear - thougths
how do you think that 13t / 33t sprocket set up will work?
faster top end? thoughts, warren
On the radar: CSC - TT250 Moto Aventure ride 2020. "If everyone is thinking the same thing, no one is thinking." Gen. Patton. -2017 Suzuki SV650 -2015 BASHAN - STORM Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black. -2005 Skyteam ST90 (sitting in pieces) -2003 Buell Blast - SOLD |
#2 | |
I don't think the internal gear box ratios are low enough to pull that final drive gear ratio.. .
Might be a little tall but may work OK depending on how you ride. My preferred ratio on my 200 is 2.64 to 1.
I ran a 13/31 with a 120/80-18, roughly equivalent to a 13/33 with a 110/100-18 and a more or less exact match to the 17/43 combination used on 428 chain setups.
It works great, but definitely road gearing territory. Good for top end and more frequent highway use in the 55-65mph range if you happen to commute or find yourself on small highways. If you want to match the venerable 17/45 combo with a 520 setup then you need a 13 front 35 rear. That is what I ended up going with on my Hawk.
#5 | |
I am running a 428 set-up. For my current set up I am running 17/47 and I will see how that goes for top speed. I also have a 42 rear, so that would be a 17/42. I will also see how that does. I am hoping that it will do at least 60-65mph. As long as it get at least 55mph I am happy as I plan to ride this on a longer ride at some point, like 3,000 mile trip.
On the radar: CSC - TT250 Moto Aventure ride 2020. "If everyone is thinking the same thing, no one is thinking." Gen. Patton. -2017 Suzuki SV650 -2015 BASHAN - STORM Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black. -2005 Skyteam ST90 (sitting in pieces) -2003 Buell Blast - SOLD Last edited by Skyteamst90; 08-18-2018 at 05:35 PM. Reason: forgot a point. |
