Old 08-14-2018, 07:24 PM   #1
Kingraider   Kingraider is offline
Kingraider's Avatar
Head Scratching ***Looking for TT250 luggage rack****
HI I'm looking for a tube style luggage rack that will fit the tt250 any one have a link of one that will fit so I can attach a rear bag ??
Old 08-15-2018, 01:02 PM   #2
Meloman   Meloman is offline
Why does it have to be a tube type rack ? CSC makes a flat rack for the TT250 that you can probably mount anything on. I currently have a Cortech tail bag strapped to it and it works fine. Being a flat aluminum plate, it can be drilled to accommodate most anything.
Re: tube type rack, I think the Bashan bikes use them and the two bikes are a similar design so they may fit with possible minor modifications.
Old 08-15-2018, 06:57 PM   #3
Kingraider's Avatar
Yea I'm considering that one I just don't want it to stick out past the tail light
Old 08-15-2018, 08:46 PM   #4
Merlin   Merlin is offline
This should cost you about $30:
https://item.taobao.com/item.htm?spm...id=10602414054
Bashan Blaze
