Old 08-07-2018, 04:53 PM   #1
jatgm1   jatgm1 is offline
Hawk 250 oil leak from silver hole
On my hawk 250 on the left side of the bike there is this weird silver cap looking thing that has two circular holes in in that it looks like u use to unscrew. It's leaking from it. I don't know what it is though.
Old 08-07-2018, 05:38 PM   #2
Which one is leaking? if it's the lower one then remove it and check the oring for damage. Or it may just be lose and needs to be snugged up. If it is the one on the cylinder jug, do not remove it. It is the cam follower shaft and you don't want the cam followers to fall into the crank case.
2004 Honda ST 1300
Old 08-07-2018, 06:24 PM   #3
It's in the cylinder jug where can I get the tool
Old 08-07-2018, 07:20 PM   #4
My hawk has a slot for a flat blade screw driver. Take a picture and post so we can help.
2004 Honda ST 1300
Old 08-08-2018, 07:40 AM   #5
NATEB1   NATEB1 is offline
Hey does anybody know where to get the after market digital gauge cluster for the Hawk 250? Also has anybody had an issue with the oil filling up in he air box and causing the bike to run like crap. It just started doing this to me and I only have 300 miles on the bike. Before ran like a champ. I was wondering if I should just do away with the air box and put a aftermarket air intake or put a PCV on it.
Old 08-08-2018, 10:06 AM   #6
Cravin01   Cravin01 is offline
Cravin01's Avatar
The oil is probably blowby, make sure you don't overfill your oil and check your case vent tube PCV valve. the case will pressurize and oil will get past the rings.
this helps explain it.
https://en.wikipedia.org/wiki/Crankc...ilation_system
https://www.motorcyclecruiser.com/un...rcycle-engines
Quoted from motorcyclecruiser.com :
" If you went through those first few hundred miles without ever holding the throttle open or revving to the power peak—or only did it once or twice—your rings probably never seated".
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 08-08-2018, 10:30 AM   #7
What is this and how do I tighten it, and where can I get a gasket and how do I replace the gasket.
Old 08-08-2018, 11:39 AM   #8
see attached Name:  cam follower Page 001.jpg
Size:  83.7 KBName:  cam follower Page 002.jpg
2004 Honda ST 1300
Old 08-09-2018, 07:14 AM   #9
Riggs   Riggs is offline
Riggs's Avatar
WTF
You need a spanner wrench.
Old 08-09-2018, 07:54 AM   #10
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
The cap is definitely different than the one on my Hawk's engine...it's slotted the same as the cap above the flywheel on the crank case. Spanner wrench is the way to go.
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
