Old 08-03-2018, 04:37 PM   #1
broseph09   broseph09 is offline
06 Diamo LS200 front wheel spacer
Hi all, I'm new to this forum and did as much searching as I can and haven't found a good answer yet.
I took my front wheel off to fix a flat tire and in the process lost the spacer from it. Does anyone know what part will work for a replacement? From what I can find the bike is modeled off of a honda xr200 but I haven't been able to find a reliable answer for what size spacer I need for it. Any help is appreciated!!
Old 08-05-2018, 08:26 PM   #2
bump
Old 08-16-2018, 10:56 PM   #3
bump
Old 08-17-2018, 02:04 AM   #4
Gh426   Gh426 is offline
Are there 2 spacers or just one on one side? Washers as shims? a cheap socket drilled out that fits the space? I've fred flintstoned stuff, may not be the best solution but...
g
Old 08-17-2018, 11:23 AM   #5
Which side is the spacer supposed to be on?
Old 08-17-2018, 05:46 PM   #6
Craig Rushton   Craig Rushton is offline
on the disc brake side. the side with the speedometer wheel already has a spacer secured with a split ring.
Old 08-20-2018, 11:26 AM   #7
Do you have a vernier caliper? If not, a cheap one from HF will do the job. Measure the seal hole that the spacer fits into. Measure the axle diameter where the spacer rides. Try to figure out how long the spacer should be.
