07-31-2018, 04:38 PM | #1 |
wheel ripped off literally:doh:
hey guys i bought a rhino 250 a few months back ,i got a good deal 900 new out the door no taxes or anything .so ive done a few mods added led pods tapped to the high beams and mounted on front rack and changed the coil springsto some ebay ones ,and ive also put it to work carrying rolls of 330ft of wire fence and pulling a few logs at first i was worried this thing would not hold but it seems preety well made only had to put loctite ona few bolts most already had it ,and so i decided to take it on a trail but ended up ripping off one of the rear wheels , called a few warehouses they want 65 for just the wheel no tire ,so i looked on offerup and found some from a rzr170 for 180 all four and it is supposedly the same bolt pattern 4x110 but is there anything else i have to look for ?
07-31-2018, 04:39 PM | #2 |
theese are the wheels im looking into
https://ibb.co/hRXx5e https://ibb.co/fraTBK https://ibb.co/jdHVQe https://ibb.co/juVjke |
07-31-2018, 07:18 PM | #3 |
How high did you get before the landing? Anyone get hurt? I can't tell you if those wheels will work. Tires will need to be very close to the same size to prevent rubbing. The wheel backspacing, bolt pattern, lug size/ type, and center hub diameter must all match to prevent a dangerous situation from croping up. You could probably find a nice set of wheels and tires on Aliexpress spec'd for your ATV fairly cheap. |
07-31-2018, 07:54 PM | #4 | |
08-03-2018, 06:11 AM | #5 | |
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
