UTV with Broken gearbox. XY300
I have a bmx/xy300 with a broken gearbox and some of the gears in the differential/pumpkin.
It is the older f-n-r single speed. They stopped making the gearbox, I am trying to find a work around to get it running. either a similar gearbox I can make work or a whole new rear end. any advice would be appreciated. |
Did you ever find this part. I need the same part for mine
https://www.amazon.com/AlveyTech-Rev...=fsclp_pl_dp_1
Not sure if you can make that work. No clue what chain size your are running on that but think you can find a sprocket to mount on it. |
Xy 300cc gear box
Hi, I am new to this forum. Did you ever find a source for your gearbox? I have the same gear box the housing is cracked in three pieces. Any chance you still have yours ? Thank you
#5 | |
Also were you able to find a work around? |
I think this is what you are looking for. Not sure who would have it available in the USA. https://www.alibaba.com/product-deta...206988042.html
