Old 07-20-2018, 12:01 PM   #1
Sclark1013   Sclark1013 is offline
Remove cat from TT 250?
There have been posts talking about removing the cat on the Hawk and/or TT250. Forgive my ignorance, but why do I want to do this? Will I really see more power, smoother idle, etc.. If I remove the catalytic convertor from my muffler, will I need to do anything else? Re-jet the carburetor, etc??? Your thoughts greatly appreciated!
Old 07-20-2018, 01:24 PM   #2
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
The catalytic converters are restrictive and get jammed up eventually...they rob power from your Hawk/TT250 and cause the engine to run hotter. The same is true for the carb - Hawks have #98 main jets stock/OEM, which causes the engine to run leaner and hotter. Changing the main jet to a #110 and opening up the exhaust (with an appropriate aftermarket exhaust) will both improve performance and allow the engine to run cooler/breathe easier. The TT250 I believe has a larger main jet and slightly less restrictive exhaust so it should be better to run stock vs. the Hawk.
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
Old 07-20-2018, 06:15 PM   #3
roundhouse   roundhouse is offline
roundhouse's Avatar
When I changed the exhaust and from a #110 to a #120 jet. I found my bike did have more power. It is not like a kick in the pants faster but my bike revved quicker and runs smoother.
Chris got it right about running cooler too. I assume the motor is cooler but the exhaust is significantly cooler.
Don;t forget the big bonus. It sounds GREAT!
