New front tire
3500 miles on the stock tires. I think it was time to replace the front tire. Rear still good for another 2000 miles.
The center stands sure came in handy. Big thanks to kirbo7106 for sending me his stock Hawk tires. ![]()
I also repacked the so called sealed bearings with grease.
My 2017 had the same style tires you just put on your bike. I am curious to see if you have the same results I did, where the rear wore faster than the front.
It's also rather amazing how bad those seals are on the factory bearings.
#4 | |
The seals popped right out with the tip of a razor knife. They snapped right back in place after greasing the bearings.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-09-2018 at 08:39 AM. |
Your pics look like the amount of grease I put on my wheel. I just replaced my rear bearings & front & rear brake pads along with new brake cylinder at 1750 miles. All existing factory Break & Bearings are WEAK & WORTHLESS! Then again my bike gets tortured through lots of mud & sand. 90% highway - 10% mud. Now to replace front bearings. Oh yah, My rear shock has seen better days. With my weight on bike I can just fit my fingers in between ebay muffler & knobs on rear tire. Noticed muffler looked polished underneath from tire rub. Best thing I ever invested in my Hawk was the dual oil coolers. |
#6 | |
![]() Edit: We had a drizzling rain the whole time we were out there. Notice how the sun came out when we got home.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-09-2018 at 03:06 PM. |
They're open underneath the seals? Haha, I didn't know that.
Are the bearings on these hubs a standard size? I think I'll need to replace mine before long. Wouldn't mind throwing in some properly sealed ones. |
#8 | |
I think Megadan has the part numbers in his Hawk Info thread.
#9 | |
![]() Front 6301-2RS Rear 6302-2RS
#10 |
Us older guys have to write that kind of stuff down. Kind of like old computers. We have to remove stuff from our hard drive so we can put more in.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-09-2018 at 03:47 PM. |
#11 | |
![]() I wouldn't say I have much of an advantage. I deal with numbers and bearings every day, so if comes second nature Ask me to remember a birthday. Or the name of somebody I met 2 hours ago and I would be screwed.
#12 |
I need to pack some grease in mine I'm sure but my miles are low so they should be ok right now. I'll be setting up a new speedo so I'll try to check it out then.
You and your bike looks like there was fun to be had!
#13 |
We had a blast. I was surprised at how many people were out even though it was raining and wet and muddy. It was a good thing there were other people out there because I don't know how we would got the UTV out. Besides the bigger tires I'm going to put one of those cheap HF winch 's on it too.
#14 | |
#15 | |
