Old 06-21-2018, 08:49 PM   #1
Ac21   Ac21 is offline
Doh! Hawk 250 assembly parts
Please help us identify where this hardware goes on the bike. I numbered it for easy reference. Thanks in advance.
Known hardware:
1 = Three of these will be used for the instrument cluster
2 = ?
3 = Instrument cluster mounting
4 = Rubber washer for fairings
5 = ?
6 = ?
7 = Rear brake pivot cotter pin
8 = One of these is used for the tank fairing(the bar behind it, do not use as the one on the tank)
9 = Front fender insert
10 = Washer for your fairings
11 = Tank fairing bolt
12 = Rear brake pedal return
13 = Rear brake light switch
14 = Front fender bolts
15 = Fairing screws
Old 06-21-2018, 09:51 PM   #2
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
12 & 13 look like rear brake pedal 4 looks like rubber washer for your fairings and 9 looks like they go on front fender. Always end up with extra bolts nuts and washers, you’ll want to save them if you don’t use locktite. You’ll need them later
Old 06-21-2018, 09:52 PM   #3
Hawk 229cc   Hawk 229cc is offline
Hawk 229cc's Avatar
#15 #4 #10 plastics screws,hose is for the battery #12 is the brake lever spring,other plastics bolts ,its kinda hard to tell the rest without showing you ,got to watch the videos on them being put together helps too,research research an more research is needed on the bikes,youtube hawk 250 assembley videos watch them all ,i had a few screws left at the end of it all i figure they put some extras in the i think it was like 5 mostly plastics extras
Old 06-21-2018, 10:08 PM   #4
You also tend to get extra hardware, so dont assume you will be using every piece in the bag.
9 looks like extra isolators for the lower headlight tabs, 3 looks to be guage cluster mount isolators.
12 is the brake returnspring. 13 is the rear brake light switch spring
Old 06-22-2018, 01:01 AM   #5
#7 cotter pin is for holding the rear brake pedal? #9 fit nicely on front fender and #14 are its bolts.
ok i was wondering why the battery was making a hissing noise and spilling acid everywhere, i left the cap on, i need to take it off and install the hose.
Old 06-22-2018, 06:00 AM   #6
6 and 7 are both for the brake pedal. The larger is for the main brake pedal pivot. The smaller one is for the clevis pin that goes through the clevis on the rear master cylinder.
Old 06-22-2018, 10:34 PM   #7
11 looks like a tank fairing bolt but you may have extra bolts. i had a whole cup full of stuff
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
