New CSC TT250
It's been at least a dozen years since I have ridden my last street bike, a Honda 250 Nighthawk (wish I'd never sold it!) and longer yet since my Husky was out. I just picked up my CSC TT250 last week and have just ridden a few miles.
I needed to crank up the shock preload and couldn't believe I had to pull the rear wheel to remove the airbox to get at the adjuster. A hat tip to 2LZ for the "trash can mod" idea. The new K&N style air filter doesn't seem to make any additional intake noise and with the side panel off the preload adjustment is now easy to make. Despite my chagrin at having to half-dismantle the bike to crank up the preload I was impressed with all the fit and finish. All of the fasteners were perfect and the threads all were fine. One thing that did surprise me was the combination of the rather tall seat height and the wide seat. Both of my Huskys are tall but have a narrow and rounded seat. The tall and wide TT250 seat is a bit more challenging to mount without standing on the pegs, but I'm going to wait a bit more before I decide on either lowering this seat or buying the CSC/Seat Concepts seat. (You don't think my lack of riding for 10 years and my increasing age are relevant do you, LOL) I had a near mishap yesterday with a failure that I have never heard of before in over 50 years of motorcycle riding. I got on the bike after some shopping and kicked up the sidestand, went to take off and nearly crashed in the parking lot (yeah I know that sounds like a total newby, but wait) when the sidestand had redeployed itself. When I tried to get off the bike the stand collapsed and I nearly went down again. Extricating myself I looked on the ground and there was the sidestand spring. I had either caught it with my boot or it had never been seated in the groove on one end. I didn't have the tool kit with me (THAT won't happen again) but managed to find a scrap bit of wire in the parking lot and tied the stand in the up position for the short ride home. I have installed a couple of c-clips on the outside of the spring grooves now, and I noticed that one end of the spring seems to have a shorter bent end than the other. Anyone else ever hear of the sidestand spring falling off? I can't imagine what it would have caught on my boot to cause this...
1978 Husqvarna 250 WR 1991 Husqvarna WXE 250 2018 CSC TT250 |
Welcome Dave. My TT hasn't had that issue luckily but I will double check it just in case. Glad things didn't turn out worse.
Welcome and congratulations on the bike. I believe you will find the bike a quality machine and the Seidner team top shelf folks.
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
try taking the hump out of the seat is my plan i have a hawk an i need to sit near the back of the bike with my near 37in inseam leg room is a must
Thanks Essayons i don't want to think too much about what kind of things could have happened on a left turn if that thing was loose! Hawk 229cc you have it exactly - what is that hump for? It seems so unnecessary I don't know what they were thinking but if I do cut down the seat that will definitely be smoothed out a lot.
Well I had an experience that was kind of disappointing yesterday. I needed to go into my office, a little over 20 miles, and no freeways needed, so I thought it would be a chance to put a few miles on the bike. I made it to the office fine, varying the speed in mind of the new motor, and was on my way back when I got a flat front tire. I did not take Megdan's advice to replace the tubes 'cause hey this is CSC/Zongshen TT250, right? Well I would have been better off to take his advice.
The real bummer was waiting nearly 3 hours for the AAA to get there for the trailer ride home, and nowhere to take a leak! Some other things became apparent:
Well lessons learned. The front tube clearly was pinched or folded over from the factory. I have two Tube Tuff Tubes on the way and should back riding by the weekend.
Sorry about the flat. How is the power on the TT250 compared to the old Nighthawk twin?
"Its not WHAT you ride; its THAT you ride" |
TT250 vs 250 Nighthawk
Using 10 year old impressions are that the power was about the same. Even though the Nighthawk is a twin it is not a very efficient engine. I never tried to take the Nighthawk on the freeway; probably a good plan. I remember commuting on the freeway on an Yamaha DT1 and I cringe now at my lane splitting youth! I am changing the standard rear 50 tooth sprocket with to a 45 when I fit the new rear tube.
I've changed most tubes on my CB's but oddly enough, I've not changed the TT250 and have yet to have a mishap. I'm hoping they make it till the tires wear out, then I'll put in the Kenda Tuff Tubes that I've had great luck with.
#10 |
I often wonder if the stock tubes would last longer if the time was taken to unseat the tire bead and add some talcum powder. It wouldn't stop puncture damage issues or pinch flats, but may extend the life otherwise. My front also blew out on mine and when I pulled the tubes there was no evidence of any kind of powder inside the tire.
They are still cheap crappy tubes, but one would expect more life out of them than a few hundred miles.
#11 | |
#12 |
Is it possible to use tubeless tires with tubes. I've seen it done on a YouTube video. The video claimed that tubeless tires are tougher against punctures; and the tube would keep you from switching rims I guess.
#13 | |
Since these bikes struggle to reach much beyond 70mph on the best of days, it isn't as much of a concern.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 06-21-2018 at 04:33 AM. |
#14 |
welcome and sorry about starting thing out a little flat.
#15 |
Seat Improvement
Flat Seat Update:
I still feel like the seat is higher than necessary for a bike with 6" travel, but at least I was able to get rid of that maddening hump. Not sure if that is supposed to be for the never-gonna-happen passenger, especially since I removed their footpegs, but I was pleasantly surprised at how easy it was to do. Several things to note:
The Tuff Tube front tube is great; now to just get the rear (arriving Tuesday) and install the new sprocket. I checked on the prices and it was a better deal to get the CSC 47 rear with the new spacers and bolts so I can choose between that and the other JT 45 tooth I ordered on Amazon. I can use the CSC supplied $27 sprocket, bolts and spacers vs. paying about $15 for just bolts and spacers at the hardware store. I also figured it was cheaper to pay the $8.50 freight vs. about 3 gallons of gas in the truck to go pick it up lol.
