06-16-2018, 05:17 PM | #1 |
Chain jumping?
I still haven’t figured out what to do about this problem. There’s definitely a couple more scrapes on the guard. I believe the banana shaped chain guide is causing it. I tried like the dickens bare handed to make the chain touch the guard but it’s not happening. I pulled and cleaned the rubbery guide, reinstalled so the rail was as straight as I could make it and added a couple of zip ties into the gap at the front trying to fill the extra space. Honestly the only way I see of getting the guide straight is to remove the large tabs and screw it straight into the upper section of the swing arm. Any help greatly appreciated. I don’t wanna die
06-16-2018, 06:02 PM | #2 |
Also, Would the chain guide even make the chain jump? It seems very weak and not really enough to move a heavy chain being pulled along by the sproket. Also youtube is full of guys just using a strip of truck mat as a chain guide, saying it's purpose is to protect the swing arm from scrapes. Glue and zip ties is what some are using to mount them, not even screws.
Here is the worst example |
06-16-2018, 07:24 PM | #4 |
Is that a hawk you have? I would check rear sprocket bolts and make sure none are broke off behind the sprocket. That is weird and yes very dangerous. When I first got my hawk I had chain pop off twice and jam up in my rear tire. Both times I was going around 30. Luckily I was able to control the bike and not crash. Would of been worse had I been going faster. Stay safe
06-16-2018, 08:01 PM | #5 | |
I haven't found anything loose yet, I did the loctite until you're insane routine when I set the bike up last month. |
06-16-2018, 08:12 PM | #6 |
I asume you have checked the chain alinement....
i would change the sprocket just in case there is a machineing defect in it.. maybe go smaller on the front sprocket and give it some room as it is very close to the engine case you really need to sort that before it takes the side of the motor out.. i think the issue is happening while coasting on a closed throttle , not under power.. ..
06-16-2018, 08:16 PM | #7 | |
It's a Storm, 480 km on it so far. The rear sprocket is as snug as it's going to get I believe. The bike will fall over before the sprocket is going to move judging by me yanking on it. You're chain jam adventures sound frightening. That's my fear, I haven't experienced the chain jamming or jumping but worry that like in traffic it will happen or worse. |
06-16-2018, 08:59 PM | #8 |
I have similar problem with jumping chain but without damage to the engine cover. I tried to change chain and sprockets, but still the same. I wonder if the clutch can cause this chain jump/vibration. My complete clutch assembly has good play in every possible axis, in relation the the gearbox input shaft, on which the clutch is mounted on. Also, the whole bike shakes during chain vibration. This happens always when accelerating but in lower RPM.
ChipToothy, is this similar to your chain jump problem? Second question is is there a way to enlarge photos from first post? |
06-16-2018, 09:15 PM | #9 | |
For pics I have to enlarge my whole screen to like 175%. |
06-16-2018, 09:25 PM | #10 |
I've been pondering this most of the day, and I'm wondering what your thoughts are, I see in my head a loose chain with either a slightly loose motor or a loose chain with misaligned sprockets. I think you don't see it that way but haven't really been able to express what might be happening.
I think I would remove the chain and attach a string to the case close as possible to the front sprocket and pull it tight past the rear sprocket to check alignment, I would also grab the motor and see if I could force movement. If that seemed well then I would replace the sprockets and hope for the best. There may be a defect in the front sprocket.
06-16-2018, 09:38 PM | #11 | |
Good line of thinking. With chain tension it is now just getting enough wear to rub on the chain guide |
06-16-2018, 09:51 PM | #12 |
Maybe it is too loose?
06-16-2018, 10:02 PM | #13 |
I think it is, I have half of the give as yours on my storm, I think when you hit a bump and the rear loses all compresion from your weight the slack gets bottlenecked in your case causing the damage.
I would adjust it tighter and take a piece of tape or color the inside of the case with a marker and ride it hard letting the suspension get full travel. If it still hits the case you'll see it in the tape or it will remove the marker. I cannot touch the suspension arm under or above but above is close.
06-16-2018, 10:09 PM | #14 | |
06-16-2018, 10:25 PM | #15 |
Most of us don't have the proper tools but that's the cool part when you can make it happen. plus it gives you a excuse to buy more tools when you can. Just wedge something like a tool box or create, the first thing to leave the ground is the rear wheel.
Make sure you adjust both sides evenly and with the bike in neutral you should be able to turn the wheel to seen if it tracks even and feel the change in tension, Too tight is just as bad.
