Old 05-31-2018, 05:29 PM   #1
304Vader   304Vader is offline
304Vader's Avatar
Vader 125cc clutch
Has anyone here changed their clutch ? If so what did you use ?
Old 06-15-2018, 01:10 PM   #2
Timpo   Timpo is offline
Do you know if the clutch is compatible to Grom?
If so I these ones would be good, also some Grom owners get dry clutch conversion as well.
Koso Clutch Kit
Barnnett Clutch Kit
EBC SRK Kevlar Clutch Kit
SP Takegawa Slipper Clutch Kit
Necto Dry Clutch Conversion Kit
SMR Dry Clutch Conversion Kit
SP Takegawa Dry Clutch Kit
Old 06-20-2018, 03:44 PM   #3
wlfpck   wlfpck is offline
I don't know of anyone that has changed their clutch. I would imagine that the Honda grom parts may fit? If not... check with Tboltusa. These grom clone engines are based on the CRF50 engine. For instance, when you look at the exhaust, you'll see that the exhaust port doesn't point straight down like it does on the grom and SSR razkull. It comes off the side. That's the CRF50 engine design.
From that... I'd say that the clutch parts for pitbike engines would fit. Give Tboltusa a call. They'll probably even be able to tell you if the grom clutches would fit.
