Old 05-31-2018, 03:14 PM   #1
Shrug   Shrug is offline
Shrug's Avatar
Head Scratching Hawk Digital Cluster
tachometer starts around 3800rpm wont go lower but still goes up less than 400 miles on it any way to take it apart.... i took it off unplugged it took 4 screws out but the damn glue they use i cant get it apart
Old 05-31-2018, 03:18 PM   #2
Does it go to zero when you turn off the ignition? Check the inline fuse and + connection. Also check the blue/white wire were you tap in has a good connection. Better to spice and solder it..
2004 Honda ST 1300
Old 05-31-2018, 03:29 PM   #3
Shrug's Avatar
no stays at around 3800 off and unplugged checked all the wires anyways
Old 05-31-2018, 04:17 PM   #4
I guess the best thing to do is contact Matt. This may be something that's happen before and he would be the best to answer your questions.
2004 Honda ST 1300
cluster
