Hawk with Mikuni Help
OK so trying to get this carb tuned and just would like a consensus of what i might need.
First off i have done the following; Air box mod w/K&N filter, upgraded exhaust,new iridium plug, and a mikuni with a 115 main and 25 slow, idle mix turned almost 2 turns due to mods, at 1 1/2 turns it didnt seem right. I have followed similar set ups for the mods i have. i am also at 650ish elevation. The issue i am getting is at idle when i blip the throttle just a bit it stalls, now if i roll on the throttle its fine? is my idle jet too small? should i go to a 27.5 or 30? is my main too small? go up to a 120? All input is appreciated.
2017 Hawk 250 1998 Harley Dyna |
You might need a 27.5. Did you raise the needle? If you haven't, try raising it one notch first and see if that helps.
#3 | |
I just didnt know what i missed as i researched and try to set up the mikuni according to similar mods and found that the 115/25 was common. Looks like each is its own beast...
#4 | |
#5 | |
This is why I always tell people to get a range of jet sizes for both main and pilot.
#6 | |
You shouldn't need anything larger than a 30.
I'm in agreement with the other guys on a 27.5 slow jet. That said, have you tried moving the clip up one notch? Does it get better or worse? It's a quick and free experiment.
That's actually a great point that I overlooked. The needle in the 5th notch might be making the jet transition too rich, so when you quickly blip it the bike just bogs out.
#11 |
Just remember to make sure the bike is fully up to temp before making any calls on jetting changes. Go take it for a solid 5 to 10 minute ride and then see how it runs.
