Old 05-19-2018, 03:04 PM   #1
Scarestone   Scarestone is offline
What is this for apollo250
What is this for? I’m tryin to figure out how to change tranny oil? I’m new to bikes so be detailed if you can. Thank you
Apollo 250
File Type: jpg 190C43BF-9D67-4B3F-B63A-11D1EB252C2E.jpg (20.4 KB, 380 views)
Old 05-19-2018, 04:36 PM   #2
Its_not_a_honda   Its_not_a_honda is offline
Apollo 250
Those 2 plugs are to access the timing maks and flywheel nut.
You will need to know that when you do any valve adjustments or timing.
To change the oil. Remove the skid plate. There is a large hex head plug facing toward the shifter. Unscrew it. Oil will start coming out! watch carfully as you remove it. There is a large spring and a metal screen behind the plug. Take the screen and clean it. Do not use anything that will harm the rubber seal. Repalce screen, spring, and plug. Refill will freash motorcycle wet clutch oil. About a quart. Replace skid plate. You can look on youtube also. There is an ok video on how to do it.
(Put oil in where the dip stick is. Right beside the kick start lever.)
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Last edited by Its_not_a_honda; 05-19-2018 at 04:39 PM. Reason: Location of where to put oil in
Old 05-19-2018, 08:44 PM   #3
I already changed the engine oil like everyone says to do awhile ago with 4 stroke full syn oil. Do bikes not have tranny oil? They just all run from the same oil? That’s whats I was asking. I would figure it would have tranny oil
Old 05-19-2018, 09:42 PM   #4
pete   pete is offline
pete's Avatar
4 stroke bikes use the same oil for both motor , clutch & trans...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-19-2018, 10:10 PM   #5
That’s crazy to me... coming from working on cars only and just how much thicker trans oil/gear oil.... just crazy to me! I really appreciate it though.
Old 05-19-2018, 10:10 PM   #6
Yeah same oil goes around the gears as goes to the piston. Be sure to use an oil that is "wet clutch" compatable though.
Old 05-20-2018, 11:35 AM   #7
ben2go   ben2go is offline
Just make sure the API label on the back of the bottle doesn't say energy conserving or resource conserving. Those oils have friction modifiers that can destroy wet clutches pretty quickly. I use diesel oil in all of my bikes, 15w-40 Rotella T.
apollo 250cc, help me., transmission
