Old 05-16-2018, 01:33 PM   #1
KS-Hawk   KS-Hawk is offline
KS-Hawk's Avatar
2017 hawk 250 head gasket leaking
Went to adjust the valves this morning and discovered that the front half of my engine on the cooling fins in line with the head gasket are coated with unburned fuel. Does anybody know the torque rating for the head bolts I'm wondering if maybe one of them has come loose with the vibration. The bike only has 900 miles on it so it should not be leaking.
Old 05-16-2018, 04:16 PM   #2
KS-Hawk's Avatar
Minor correction I misspoke myself it is actually oil coating the front part of the engine near where the head gasket is.
Old 05-16-2018, 06:48 PM   #3
Torque for the head bolts is around 24 to 28ft-lbs. I have mine torqued to 28. Mine atarted to do the same thing and i found 2 were loose. Mine stopped seeping after i re-torqued the head bolts. Make sure to do a criss cross pattern.
Old 08-25-2019, 09:32 PM   #4
iser_ken   iser_ken is offline
My 2017 Hawk is doing same thing. i tried to tighten bolts, but everything is tight... i think the head gasket is shot... i think i read somewhere, its a common thing?? has anyone changed a head gasket on it??? comments and opinions are welcome... not looking foward to this project.
Old 08-25-2019, 11:49 PM   #5
Sochin   Sochin is offline
Sochin's Avatar
It is NOT a hard job..........if you are handy with tool, you will have the head off in less than an hour, new gaskets on amazon or ebay. Just search cg250 headgasket. I replace mine when I put the updated CSC TT250 head on mine. Hasn't leaked ever since.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 08-26-2019, 08:06 AM   #6
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
I’ve always sprayed my head gaskets with this stuff. I’ve never had problems after. It can make a bad gasket work again.
You’ll have to readjust/check your values after everything goes back together.
File Type: jpg D562F7E4-3FAE-4F3E-8A6F-EB6DA23D728D.jpg (7.4 KB, 578 views)
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
