05-11-2018, 09:07 AM | #1 |
Apollo 250rx build help.
Hey! I’m new to bikes so there’s a lot I don’t really understand completely. I’m deeply into cars and always working on them. So staying “stock” is just not something I can ever seem to do. I’m not trying to fly around a track. Just need links to upgrades that are smart to do. I really do like the bike so I’m trying to keep it going for as long as possible. If you could also leave me a link to the “upgrade” I would appreciate it! Thanks.
05-11-2018, 09:39 AM | #2 |
Welcome aboard! Nice looking bike 1st red one I've seen on here. Don't worry, as soon as those Apollo members wake up they will help you out. lol
05-11-2018, 09:55 AM | #3 |
Welcome! I have a 2017 apollo 250. Great bike. The more you ride it the more it breaks in and loosens up. Gets better and better. I have a 12 tooth front sprocket and a carb mod on mine. This isnthe link for the install: http://chinariders.net/showthread.php?t=21082
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
05-11-2018, 11:02 AM | #4 |
Thanks! Seems like a lot of good people here! I also have a small problem possibly. There is a small valve at the top of my rear shock I pressed it in and “air” came out and now the shock is super soft... what do I do to fix it back? Is it just a bleeder and it had to be bled? Spring is all the way out too for a softer ride.
05-11-2018, 11:14 AM | #5 | |
05-11-2018, 11:42 AM | #6 |
Welcome! Looking forward to following your upgrade progress.
05-12-2018, 08:39 AM | #7 | |
I am by no means a shock expert but that does not sound good. I would think it is charged with nitrogen or some kind of gas. Probably at high pressure too. You might look on youtube and see how to recharge shocks. I wound my spring nut out one round. I was going to put on a different shock to try to soften the rear up some. I am going to wait a while now. The more I ride the softer it gets. I weigh about 195 BTW. Let us know what you do to get the shock back in action.
05-13-2018, 02:11 PM | #8 |
Correct, that is a gas charge port. The idea is that you can adjust the pressure in the shock to change the firmness of the dampening/ride. It's kind of like a pneumatic preload.
Tags |
apollo 250, build |
