Old 01-21-2008, 12:58 PM   #1
Guest
Posts: n/a
experiences with my new toy
Well, I did it; despite the freezing temperatures, I went out and took pieces off the bike. Specifically I removed the right side plastic stuff so I could get to the battery within. I do not know about you guys, but my battery is in a solid metal box, which feels as if it will keep it there well. Brought the battery into the house and put on a 2-amp charge. The top of the battery says slow charge .7 amps for 5 - 10 hours or fast charge 3 amp for an hour. I figured two amps for 1.5 hours might work.
I noticed that the chrome fasteners are in fact pretty darned cheapish. In addition, the bolts that attach the battery cables are not a perfect fit. However, from what I can see everything is still fine.
I have already managed to chip some paint off the side panel and figure a touch up with some model paint would do the trick.
What I really like about this bike is that the price I paid makes me not so afraid to mess with it. I am going to auto parts store today for a new spark plug and see about getting a better coil wire.
This thing is heaps of fun I been grinning for days
Old 01-21-2008, 03:23 PM   #2
Guest
Posts: n/a
new plug
Managed to install new plug. Old plug was off a bit but was an NGK. Keep getting compliments on this thing. Just wish that silly 5 on the front would go away . . . far away.
Old 01-21-2008, 04:54 PM   #3
liverchip   liverchip is offline
Send a message via MSN to liverchip
Stickers/graphics are made to be removed!
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 01-21-2008, 05:52 PM   #4
Q   Q is offline
Re: new plug
Hard to remove the 5 since it's been clear coated so I got a bumper sticker supporting my pick in the 08 presidential race and covered it up.
Q
Originally Posted by zapkin
Managed to install new plug. Old plug was off a bit but was an NGK. Battery situation is solved. Keep getting compliments on this thing. Just wish that silly 5 on the front would go away . . . far away.
Old 01-21-2008, 05:55 PM   #5
AZ200cc   AZ200cc is offline
Sounds like a time to pick a new color and sand that five off that plastic.
Or just pick at it until you get it off And spray some new clear on.
Old 01-21-2008, 06:05 PM   #6
Guest
Posts: n/a
AZ have you tried the removal and clear coat yourself? I was actually considering gettin a big "steal your face" dead sticker and planting that sucker right over it
Old 01-21-2008, 06:17 PM   #7
I started to pick at some of the ones on my old bike, And finally decided that they liked being right where they were at If the paint survives the peeling process it should be pretty easy to get a rattle canof clear and shoot some on after you get all the old adhesive off.
Old 01-21-2008, 06:35 PM   #8
pumpkin   pumpkin is offline
if i remember rite jim put a gy-2 fairing on his because they are just a plain matching color. i'm not sure about price
06 american lifan 200 gy-5
Old 01-21-2008, 06:43 PM   #9
Guest
Posts: n/a
what about taping area around the sticker off and then just spray painting red over the dang thing?
Old 01-21-2008, 07:30 PM   #10
Well sure..If You want to do it the easy way
Old 01-21-2008, 08:22 PM   #11
I never did a thing the easy way :mrgreen:
I got so tired taking off and putting on that plastic I just left it off after a while. 8) The more poking around you do, the more you will see what your bike needs. Then you start thinking about it for a time. After a while all that's left is the fixing. Good Luck Zap n2r
Old 01-21-2008, 09:59 PM   #12
Jim   Jim is offline
Yeah I put a gy2 fairing on it, I ordered it from Tom at RPM, I honestly can't remember the price, but it was reasonable. Tom is a good guy.
Anyways, the battery tray that you said looks like it should hold it in place, may... Mine cracked eventually and had to be welded back together, just another thing to keep an eye on
"Be excellent to each other"
Old 01-21-2008, 11:58 PM   #13
Guest
Posts: n/a
thanks for the tip and will do on the battery tray.
Old 01-22-2008, 05:31 PM   #14
my battery box cracked as well, but i thought it was from replacing the battery 4 times.
Old 01-22-2008, 08:09 PM   #15
Guest
Posts: n/a
I wonder if it would be worthwhile to use JB weld to reinforce the battery box.
