04-30-2018, 09:55 PM | #1 |
TT250 Electronic speedo accuracy ?
Are the new electronic speedometers more accurate than the old cable version ? I rode past two different roadside radar screens and my electronic speedo was right on the money.
04-30-2018, 11:26 PM | #2 |
They might have made some improvements. How does its acciracy stack up ahainst GPS? Those roadside radars aren't always the most accurate things either.
05-01-2018, 07:49 AM | #3 |
If it's a 2018 TT250 it has the same digital cluster that us Hawk guys have installed. Pretty accurate.
05-01-2018, 09:20 AM | #4 |
If its electronic can it not be calibrated if it isn't accurate?
05-01-2018, 10:06 AM | #5 |
Dan, I have an IPhone 5S with some sort of gps program on it. How do I get it to read mph ?
05-01-2018, 10:58 AM | #6 |
mjstef may be able to chime in on this. If you install his electronic cluster, as we did on our TT250, then set it for a 19"(?) front wheel, I think it's right on or seriously close.
05-02-2018, 10:13 AM | #8 |
My electronic speedo came with the bike (2018 TT250). How do I use my Iphone’s gps to show speed ? I’ve never done that.
05-02-2018, 10:16 AM | #9 |
Download a speedometer app.
05-02-2018, 10:23 AM | #10 |
Really? Or are you yanking my 428 chain ? Got a link ?
05-02-2018, 10:26 AM | #11 |
I'm not a IPhone user but you should be able to download from your Apple app store. On the Android phones there are tons of free apps.
05-02-2018, 11:02 AM | #12 |
Thanks, found them.
Now what’s the best device to attach my phone to the bike ? |
05-02-2018, 02:18 PM | #13 | |
The cheap DIY solution for about 5 bucks. http://www.chinariders.net/showthread.php?t=18913 Or you can simply get a Ram mount system with a bar clamp for around 50. Likely you could find some cheaper options out there too. I have a Ram X Grip and a socket arm that I can swap between bikes. I installed a steering stem mount kit on my VFR, and I have a bar clamp setup I used to use on my Goldwing that is now on my Hawk. I just transfer the X Grip between the two.
