Engine Help 125cc
Hello I got a new head cylinder for my 125cc, now its sounding like this.
I adjusted the valves. I checked timing seemed right only thing i can think of is if I put cam on 180? timing? anyone help please? Thank you https://streamable.com/zpb11 Last edited by Chinabike; 04-26-2018 at 12:51 AM. |
Can anyone help?
going to redo the head cylinder and timing today. |
Is there any chance that the oil feed hole in the head gasket is partially blocked? It sounds like it's starving for oil.
I'll check. But not sure exactly what hole you are talking about?
Thanks wasn't that. Had the timing way off.
Now running pretty good. Just a little tapping at the Head. Think i need to readjust the valves again. |
Whew! Glad there was no internal damage.
"Its not WHAT you ride; its THAT you ride" |
That's an easy mistake to make. Glad you got it sorted.
#10 |
thank all for the help.
One question, I have my valves set at .005/.005 and have a little tapping/ticking from the head. should i go up or down with the gaps... to try an eliminate the tapping? |
#12 | |
I report back once i adjust. thanks Last edited by Chinabike; 04-29-2018 at 11:10 PM. |
#13 |
Ok i adjust the valve to .003 / .004
main jet 120 fuel/mix 1 1/2 turns That taping is quieter but now it sounds like this. Like it has the hiccups? Cutting in and out. https://streamable.com/uj84e |
#14 |
Just rode it for about 30min. Got it up to 44, i didn't want to push it anymore. It feels like it can hit 60 even with the problem....When its driving it acts its jerky, seems to pull back and forth. at idle it will die or idle up and down between 2000rpm and 1100rpm. Any help?
#15 |
Maybe its the spark plug? I only had a old one. Just a thought.
