Jet advice
Hi All
New bike runs like crap. So I need to jet the carb. First I ordered a mikuni form Amazon and jets from jetsrus. I am sitting 400Ft above sea level in a cold climate. I was thinking of starting with 27.5 and 110 jets. Bike is stock. Do you guys think this is a good starting point? The only other problem I have had with it is the headlight. Need to find where the bad connection is. its either on the bulb or connector as it is on and off with a wiggle of the wire. Going to love this bike. it is already fun to ride even if it runs like crap. Thanks for your input! |
Please tell us which bike and engine you have. That makes it easier to suggest jet sizes.
Sorry good call.
i have the hawk 250. |
That's why it's always good to put what you have in your sig and what mods.
I would say that your starting point on the jet sizes is a good one to begin with. I ran essentially the same setup on my Hawk when it was stock in warmer temps and found it to be a bit on the rich side with the 110 main, so in a cooler climate it should work out well.
