04-10-2018, 04:07 PM | #1 |
Holy Moley!
Used my Hawk to get go work today since it was a nice 60 degrees outside. I think I found my setups happy place, because I managed to hit 75mph in the exact same stretch of road where I previously maxed at 71. I was also able to cruise along at 60 with more than 1/4 turn of throttle left.
That speed on a Hawk with occasional cross winds is really scary if you are wondering. Shinko 705s also make a lot of vibration. My behind was getting a bit tingly lol. Oh, and this is with the silencer in on the exhaust.
04-10-2018, 04:10 PM | #2 |
LOL, yes it does get a little scary after 70 mph. You are now officially in the 75 mph club. lol
04-10-2018, 04:14 PM | #3 |
Yeah, and I havent even put the ported head on yet. Maybe I can join the 80mph club lol
04-10-2018, 04:17 PM | #4 | |
http://chinariders.net/showpost.php?...01&postcount=7
04-10-2018, 04:47 PM | #5 | |
04-10-2018, 04:49 PM | #6 |
morphed into a wing suit!
04-10-2018, 05:09 PM | #7 |
Out here in the desert, my Hawk tops out at about 65-67 if I lean WAY over the handlebars. The tires are still the stock knobbies, and it gets really sketchy. I'm not at all happy with the bike going anything faster than about 50-55. The ruts/ridges/potholes out here really throw the bike for a loop, too. If you hit a pavement seam, it'll make the bike wander all over the lane. I'm not even interested in trying to get anything else out of the little bike because the steering and suspension is so questionable. It's a fun bike for what it is, and it's my go-to for running errands around town, but sinking a ton of time effort and money into it to try to wring every last drop of performance out of it isn't on my to do list any time in the near (or distant) future. All that being said, I'm glad you guys are having so much fun tinkering around with the bikes, and the numbers you're putting up there are truly impressive!
04-10-2018, 05:21 PM | #8 |
If my jacket opened, i would have probably slowed to 50 lol.
I wasnt even tucked in. And yes, I am a huge parachute myself lol
04-10-2018, 07:41 PM | #9 | |
04-11-2018, 01:53 AM | #11 | |
Plus 90mph on a Hawk would be borderline terrifying lol
04-11-2018, 05:47 AM | #12 | |
04-11-2018, 06:38 AM | #13 | |
I run 15wt oil in my forks. I usually start there, and then go up or down to tailor the dampening to my liking. I run 210ml now in my forks, with 54mm of preload. I also weigh about 90lbs more than you do though. Megadan, the name means something... lol The stock spacers in my forks were 15mm. My first set of spacers I made were 38mm, and while still a touch soft for me, might actually work out well for you. You can actually swap out the spacers without having to take the forks out. Just do one side at a time. Then sit on it, ride it about, see if you like it, or want to add or remove some. 7/8" OD tubing/pvc cut to length, or you can stack washers in with the original preload spacers until you find what you need. What you want to aim for is a combined sag (static and rider weight) of about 2 1/2-3 inches with your weight fully on the bike. From there you can experiment with fork oil levels. I would suggest starting with 160-170ml and take it out for a ride. There are 2 aspects you are looking to tune. The weight of the oil will alter the compression and rebound dampening. 15wt seems to be effective for most of the owners that have changed out the fork oil, including me. If the damping rate is too stiff, you can always try 10wt, not stiff enough, 20wt. The level of the oil will change the air spring effect. More oil - higher air spring effect, which is a progressive increase in fork stiffness as the forks compress. If you are riding and feel the suspension is still too soft feeling, add 20ml more to each fork, ride it, repeat. If you feel it is close to ideal but still want a little more, add 10ml to each fork. If you go too far and it gets too stiff, a big measuring syringe with a hose on the end is an easy way to remove some oil without having to take the forks off. Just make sure that you measure out the amount to remove in the syring, and drain the hose off back into the fork to help keep track of what was actually removed. I do know that my buddy who is close to your weight rode it with 38mm spacers and 210ml of oil thought it was just about right for him. So, that could be a decent starting point at least. Welcome to the world of dampening rod fork tuning lol.
04-11-2018, 08:55 AM | #14 |
I haven't rode bikes a long time or a whole lot in general. I don't really know what good forks are supposed to feel like...So maybe that's why I haven't noticed the sketchyness at fast speeds...seems just like riding fast to me...
I can relate with the tingling in the backside though Dan! Haha. That bike sure does vibrate at high speeds. The only thing that sketches me out is the picture that appears in my head of the bike rattling/falling appart high speeds. I can't help but always think about that when I'm riding at high speeds... |
04-11-2018, 09:05 AM | #15 |
I found that when I run the 17/40 sprockets I don't have the vibration and the bike just feels safer at higher speeds. With the 15/40's I feel lots of vibration at higher speeds and 16/40 not as bad. I think the high rpm's just makes your brain think you are going faster that you are. I've been running 17/40 lately as I have been doing more street riding.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-11-2018 at 11:32 AM. |
