Old 04-09-2018, 11:52 AM   #1
My TaoTao Hellcat 125cc
This is my new 2017 TaoTao Hellcat 125cc.
Current Mods.
Painted Black
FenderEliminator / Led rear turn signals
New shift lever
Some bolt upgraded or Loctite
Next Mods.
Carb
Muffler
Handle bar
Old 04-09-2018, 12:12 PM   #2
Mowgli   Mowgli is offline
What bolts didn’t you upgrade and where did you order them from?
The black looks good
Old 04-09-2018, 12:31 PM   #3
So i only replaced the front and rear axle with grom ones that my friend gave me but here link to them and part number.
44301-K26-900
https://www.amazon.com/Honda-44301-K.../dp/B00NO00EHM
42301-K26-900
https://www.partzilla.com/product/honda/42301-K26-900
These are all the bolts i have order so far, hope it helps. But haven't installed them yet. I figured i'll just see how the stock go with just lock tight and keep checking them. I'll keep the new ones on hand if needed. I'm not going to be doing any stunts or wheels, easy riding . So i think it will be ok.
https://www.ebay.com/itm/Honda-Bolt-...72.m2749.l2649
https://www.ebay.com/itm/8mm-M8x1-25....c100005.m1851
Old 05-01-2018, 12:02 AM   #4
Ok update on my Hellcat.
Seems to be running pretty good right now... after my cylinder head fiasco.(My fault...broke a intake bolt and ruined the hole trying to get it out.) I had to replace the head and adjusted valves and timing a few times.
Rode it today easily got to 50 but didn't want to press it yet. Keep it around 25-45 for a hour.
Definitely feels like it wants to do more. Seems to be running better the more i ride it.
Current Mods.
Muffler
17t front
Uni airfilter
Mikuni Carb
26mm intake
fuel line/filter
Painted Black
New shift lever
Grom Chain tensioner
New ngk plug
New cylinder head
Old 05-02-2018, 12:10 AM   #5
Old 05-02-2018, 04:57 PM   #6
Ceasar1010   Ceasar1010 is offline
Nice work , this is clean
Old 05-02-2018, 11:39 PM   #7
What bolt did you break that caused you to replace the whole head?
Old 05-03-2018, 12:41 PM   #8
I broke one of the intake mount bolts, i pretty much f'd it up more trying to take it out. Totally my fault breaking it. i didn't know if it was fixable and the cost to fix was more then a new head... here some pics
replaced with this
Old 05-03-2018, 01:40 PM   #9
Your old head is fixable. Pick up aluminum welding rod at Harbor freight, Propane torch, fill in hole and drill and tap for bolt. Done this a few times on outboard motors before youtube was invented lol.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 05-03-2018, 02:10 PM   #10
Was the bolt to long that you put into it? I noticed the kit from amazon the bolts bottomed out in the engine case. I’m just hoping I didn’t bust into the engine case but I haven’t had issues yet.
Old 05-03-2018, 03:14 PM   #11
[QUOTE=JerryHawk250;279093]Your old head is fixable. Pick up aluminum welding rod at Harbor freight, Propane torch, fill in hole and drill and tap for bolt. Done this a few times on outboard motors before youtube was invented lol.
Thank for that video i was wondering how to do that. I might give it a shot some free day. But i don't know if it would be worth the time and money. I would have to buy a few tools and materials. New head was only $60
Old 05-03-2018, 03:20 PM   #12
Yea... i didn't notice the bolt was to long and i over torqued it. ugh! ha. Live and learn,
why i got a Chinese bike.
Old 05-03-2018, 11:27 PM   #13
I had to swap the bolts that were on the old carb since they are shorter. Did you actually punch through the head or did you just rip the threads out?
Old 05-04-2018, 03:18 PM   #14
Snapped the bolt flush to the head.
Old 05-10-2018, 07:33 PM   #15
I adjusted the valves so many time and i still can't stop the tapping on the new head. Owell. Still braking her in but got a top speed of 57mph
Added new
brake and clutch levers
Pipe wrap
