What to do to set cooling fans to stay stop automatically
Hi
I have swapped a liquid cooled engine in my bike. Currently with fans on is Temps are below 80. I have connected them directly to battery and a switch is in between so if I have to start/stop them I have to manually do that. What I need to make them automatically turn on or off when a temp reaches certain limit? Can you guide me about components needed? I will be able to speed them up. Currently thermo state switch has only one plug and it only shows Temps. I would also like a feature where it gives some audible tones if Temps reach certain abnormal range. Regards |
You will need something like this. Just have to find the right temperature range you want. https://www.ebay.com/itm/170-185-Deg....c100005.m1851
