03-11-2018, 04:08 PM | #1 |
what part is this called?
125cc.
what is coming off the head to hardline elbow that joins to soft line with coil line? with brass clamp? http://imgur.com/sNVuVEc |
03-11-2018, 08:12 PM | #3 |
thank you sir! that is what i was leaning toward. i appreciate your answer! i would try to search the name to find a shut off plate.
03-12-2018, 07:45 AM | #4 |
You're welcome.
03-15-2018, 10:19 AM | #5 |
cant believe no one makes this block off plate on a lifan
i circled the area where no one sells a cut off/ block off plate.
i found one for the gy6 engines but been searching for days for the lifan.Attachment 12201 Last edited by imapdog; 10-30-2019 at 02:42 PM. |
03-15-2018, 10:41 AM | #6 |
Why not spend 5 minutes and make one ?
03-15-2018, 10:47 AM | #7 |
i may just create a cad file for machinist and sell these. since no one is.....
and i wish i had the time to kill at work making one, but i work in a office sun up to sun down. wish i could save the learning curve time on my weekends by simply ordering one while i am at work killing time searching this stuff.. lol |
03-15-2018, 01:23 PM | #8 |
searching lifan egr blanking plate helped a lot
found one in england! i will post pics once installed. no one in the states sells this for a lifan. as far as i can find. not much chatter as to why gasket is needed or not for perfect seal....
Attachment 12203 https://www.chinesemotorcyclepartson.../partno_EGR001 Last edited by imapdog; 10-30-2019 at 02:42 PM. |
03-15-2018, 02:10 PM | #9 |
You're over thinking this. Order the one for the GY6. Bolts center to center should be around 30-31mm. if you want to check for fit. Personally I would just cut one out of a piece of 1/8" plate steel or aluminum and some gasket material.
Nice one on Amazon. Slotted so should fit. https://www.amazon.com/NCY-EGR-Block.../dp/B01M1NL97F
03-15-2018, 02:25 PM | #10 |
Make a template out of some cereal box cardboard. Get some 1/8" steel at the local hardware store or scrap metal place (cheap). Trace template, drill holes, and cut shape. Either pick up a new gasket, or make your own. Done.
That said, for $7, it's hard to pass up simply ordering, waiting, and installing. Depending on where you can get the steel from, you might save a few bucks if you have the tools to make your own.
03-15-2018, 02:52 PM | #11 |
thanks guys. i pulled out the legends. i do overthink.
03-15-2018, 06:39 PM | #12 |
I remember seeing a video on the tube. The bracket that mounts the valve (to the frame) or whatever that the hose goes to is actually a block off plate for removing that crap. Seems our Chinese brethren KNEW we would want to remove it. Let me see if I can find the video.
03-15-2018, 06:50 PM | #13 |
I can't find the video again in the hundreds I have watched, LOL. But basically that line / hose comes off the engine and runs up to some kind of diaphram valve that is attached to the frame with a bracket. That bracket in this guys video was actually a block off plate. I found it pretty cool. Wish I could find the dang video. I believe it was on a Tao HellCat, could've been a Vader too.
03-15-2018, 09:35 PM | #15 |
if it were a snake it would have bit me
right under my nose. they actually did leave me a block off plate to use.
Attachment 12204 Last edited by imapdog; 10-30-2019 at 02:42 PM. |
