02-28-2018, 09:56 PM | #1 |
Removed the hawk from seat, gutted stock exhaust cat
Tackled 2 big things today on my hawk. Finally got that hawk label off of the seat. Took some brake fluid on a rag and rubbed the crap out of it nice and hard for 5 minutes and the letters disappeared no problem.
Also cut the exhaust and removed the stock cat. Holy hell was that a headache. Would of been easier to cut it out and replace it completely. But after almost 2 hours I had the cat out and it welded wrapped and re installed. I drilled around. Hammered a punch in and used pliers to rip it all out little by little. |
03-01-2018, 07:51 AM | #2 |
It was tough to remove . Welding another piece of pipe In there would of been easier. When I did mine it was a spur of the moment thing and didn't feel like going out a getting a piece of pipe. In the end it was well worth the effort.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-16-2018 at 04:48 PM. |
03-01-2018, 10:29 AM | #3 |
I removed one from a scooter muffler once that was an absolute bear. It amazes me that the engine can even start with the cat in there.
03-01-2018, 08:43 PM | #4 |
Thanks for the tip with the brake fluid and the seat.
03-02-2018, 10:57 AM | #5 |
Brake cleaner also works to remove lettering on a vinyl seat, but use it sparingly.
03-28-2018, 10:46 PM | #6 |
Where is the cat located on the exhaust?
03-28-2018, 11:10 PM | #7 |
Right behind the heat shield next to the cylinder. Take that heat shield off and it will be super obvious where it is.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 03-31-2018 at 06:03 PM. |
