Old 02-24-2018, 10:16 PM   #1
rd1959   rd1959 is offline
spark plug size
Hello all. I'm getting prepared to do my first valve check and realized I don't have a spark plug socket. What size socket will I need? Thanks.
Old 02-25-2018, 12:29 AM   #2
Standard 5/8" spark plug socket will work. Don't need any of those super thin walled ones like some require. You'll need a short extension. Suggest compressed air to blow out any dirt and small rocks from the recesses around the spark plug before pulling it so nothing falls into the cylinder hole. Also suggest going from a series 7 plug to an 8 as it's a bit hotter but not too hot like a 9. This was a suggestion from Gerry at CSC.
Joe
2017 BMW F800GS Adventure
Old 02-25-2018, 07:24 AM   #3
Thanks. Going to a hotter plug sounds like a good idea. Currently, most of my riding is short 8 mile trips back and forth to work. I assume a hotter plug will stay cleaner.
Old 02-26-2018, 12:45 PM   #4
Haggis   Haggis is offline
Haggis's Avatar
If it's an NGK plug higher numbers mean a colder running plug. For short trips or town running with the engine maybe not reaching full temperature an NGK with a lower number will run hotter.
