Old 02-18-2018, 01:26 AM   #1
rjmorel   rjmorel is offline
rjmorel's Avatar
Why?
Can someone tell me why these Chinese bikes chain adjuster thingy is upside down with the engraved alignment lines facing down to the road? I tried flipping them the right side up but you can't because it's off centered. It's almost like someone welded the swing arm "arms" on upside down when putting it in the welding jig. ??????? rj
Live Zong, and Prosper
Old 02-18-2018, 10:17 AM   #2
Just guessing....the axle rests on the arms and the indicators ride along. If it was the other way, the indicator takes the weight, gouging the arm during movement. They may get 'cocked' also.
It's strange that most CB's are based on Hondas but the box style swing arms are often found on Suzukis.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 02-18-2018, 11:23 PM   #3
have you tried swapping sides and turning them up?
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 02-18-2018, 11:31 PM   #4
ok went and looked at mine it is in the same position as your. mine has an alignment hash mark at the top of the circle and on the swing arm theres lots of hash marks right above the circle with the mark. i suppose your saying the marks on the swing arm are on the bottom????
2016 hawk
kaw h1 400 tripple
Old 02-19-2018, 12:16 AM   #5
rjmorel's Avatar
I'll look again tomorrow but I didn't see any circles or lines on top of swing arm. I'll post a close up pic of how mine are tomorrow, rj
Old 02-19-2018, 03:12 PM   #6
rjmorel's Avatar
Nothing on top or bottom for alignment marks, rj
http://www.chinariders.net/attachmen...1&d=1519066450
Old 02-19-2018, 04:17 PM   #7
I align the rear wheel by the chain. I have the Motion Pro tool. Before that, once I set the proper chain slack, I would measure the distance from the adjuster to the end of the arm on the chain side. Then I would set the other side the same.
2016 Rhino 250
2016 Tao Tao 125D
