02-05-2018, 12:13 AM | #1 |
Looking for Hawk rear sprocket snap ring
Hello!
I'm installing new better rear sprocket bolt's and I like a new snap ring for backup. Any body know where it can be found for Hawk? Thank's |
02-05-2018, 08:00 AM | #2 |
I would first try CSC (California Scooter Company), if no luck there, try RPS (Ricky's Power Supply). RPS is way more expensive, from what I've seen....ARH
02-05-2018, 08:37 AM | #3 | |
https://www.mcmaster.com/#snap-rings/=1bfr6b3 Or MSC Direct: https://www.mscdirect.com/browse/tn/...vid=4287879270 |
02-05-2018, 09:36 PM | #4 |
Hello!
Thank's for your reply,I found one that may work. I'll post back if it fit's when I get it. Thank's |
02-06-2018, 03:42 AM | #5 |
In case the one you found does not work. This is a direct replacement. The price on Amazon i silly high, likely due to a low supply. Take those same specs and search on MSC or McMaster as linked by tlelectric and you will likely find one relatively cheap.
https://www.amazon.com/gp/product/B0...648f496f3eb832 Or, as mentioned previously, simply order a TT250 unit from CSC. A whole 95 cents plus shipping. http://www.cscmotorcycles.com/TT250-...p/zt24-100.htm
02-11-2018, 12:42 AM | #6 |
Hello!
I used it and I like it better than OEM one. It seem's to have more clamping force and stronger. Ten in a pack for $10.15 Link to it. https://www.zoro.com/rotor-clip-reta...6/#description Thank's |
