Hawk 250 headlight
can i switch my hawk 250s headlight to an after market one i just don’t really love the look of it??? i already got a new cluster
You can put any headlight you want on there. Might have to rig up you own brackets or some kind of fork tube mount depending on the light you want to use. A round coversion will likely be the easiest.
what about this
what about this one? https://www.2wheel.com/polisport-mmx...8aAl3-EALw_wcB
#6 | |
2012 Kawasaki Versys 1984 Honda Magna V65 2016 Rhino 250 2016 Tao Tao 125D Last edited by david3921; 01-08-2018 at 03:25 PM. |
#7 | |
avoid cheap assemblies as the optics in the lens and reflectors will not be good (much like the stock assy.)
a standard 5" or 7" round works, BUT (as i learned the hard way) be sure to mount low enough for a 1/2" of free space between the headlight bucket and the ignition switch lower housing (which has plastic tabs that can easily break)
———— ‘16 Hawk 250 changed up a bit ‘85 Virago 1000 changed a bit more |
can you guys maybe send me some that would work i’m new to the bike community somewhat but am eager to learn more
#10 |
ubiquitous parts, many resources, search for 7" headlight bucket and bracket
this will be a headlight and mount like an old-school UJM the bracket attaches to your forks between the upper and lower triple-trees (fork removal not required) the sides of the bucket have threaded bosses to attach onto the brackets your wiring will tuck into the bucket the stock Hawk forks are kinda slim, so be sure to have flexible shim stock on hand if the brackets don't cinch up
#11 |
If I had the choice, I would use sections of rubber hose as shims for a fork mount. Much better at isolating vibrations. It just really depends on how big of a gap we are talking though.
Tags |
hawk 250 |
