Old 12-01-2017, 04:53 PM   #1
J-May   J-May is offline
J-May's Avatar
Send a message via ICQ to J-May
$3 fender delete Boom/Vader
Are you sick of the diving board of a rear fender and luggage rack that can barely hold your helmet. Well I got a solution for you. That costs only 3 dollars and little bit of time. Find yourself a "6x6 post connector" that's what Menards calls it and drill 2 holes in it to mount to the rear most bolt holes that hold the luggage rack in place. Then drill 2 holes, 1 on each flap for the turn signals. The license plate light is mounted just under the brake light there were 2 small holes that I oblonged out slightly to mount the light housing. Some people may not right at night so you can ignore that part I drilled a hole in the top middle of my plate and the bracket to mount the plate and bolted it all together, the results are a decent looking. I left it unpainted so it is easier to see what it looks like. I plan to take it off and paint it Black in but it makes the bike appear much more sporty.
This idea was borrowed from a guy on YouTube here's the link to show the process he used. I did the same and modified it for the Boom/Vader
File Type: jpg simpson-strong-tie-caps-lpc4z-64_1000.jpg (57.1 KB, 703 views)
Old 12-01-2017, 04:55 PM   #2
J-May's Avatar
More pictures and this is 100% reverseable and can be put back to original since the stock parts have not been hacked up at all.
