Hawk leak
So this morning I woke up to a oil leak under my bike. Can anyone tell me why this is leaking and if I can fix it. Thanks
Looks like a head gasket seeping oil.
That or one of the O-rings that seals the oil passage between the head and cylinder has went bad.
Head gasket
Head bolt torque is 29lb-ft. If you remove the head, retorque in at least 2 stages in a criss.cross pattern.
So i got my new gaskets in today. How hard is it to change them out?
Not hard, just don't drop your pushrods down inside LOL!
#10 |
So I tourqed it at 29 ft lb and it still seems loose is this correct
#11 |
No, it is not correct. It sounds like something wasn't seated properly.
#13 |
After a couple of full heat cycles or say 100 miles of riding, it would be a good idea to go back and check those head bolts one more time.
#14 |
What size is the pilot/slow jet in that carb?
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#15 |
Not sure,whatever comes stock on the hawk. Just got back now and it seems to ride fine besides a burple sound when I release throttle while moving. Is this normal should I go back to 115?
