Old 10-25-2017, 10:18 PM   #1
Lube da chain
Easy way to lube chain. Leave kick stand down and pick up on back while pushing forward. slide 2by4 or stick under swing arm. Lift is only 25 lbs or so. Spin wheel while spraying. it balances on the front wheel and kick stand fairly easily.
File Type: jpg 22713321_10208487335935902_5888446940768354733_o.jpg (97.4 KB, 262 views)
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-26-2017, 07:35 AM   #2
I've done that a few times except I had a 2x4 with a V notch and put it under the axle bolt. That's why I made the center stand.
2004 Honda ST 1300
Old 10-26-2017, 01:37 PM   #3
dh   dh is offline
Great idea and thanks for sharing! I love the ammo can panniers.
Does anyone use gear oil instead of chain wax? I just put on a new RK racing chain and the maintenance instructions say to clean and lube every 200 miles using gear oil(80w-90 I think). I always use spray wax buy hate the mess I end up making with it.
Also, how do you know when a sprocket is worn and needs replacing? My new chain is noisy and need adjusting more than I though it would. Would this be caused by a worn sprocket? The front sprocket has about 8,000 miles on it and looks ok. I have 14,000 miles on my original rear sprocket and it doesn't appear worn on the sides but maybe some wear between the teeth?
2013 SSR XF-250
Old 10-26-2017, 01:44 PM   #4
Originally Posted by dh View Post
Great idea and thanks for sharing! Does anyone use gear oil instead of chain wax? I just put on a new RK racing chain and the maintenance instructions say to clean and lube every 200 miles using gear oil(80w-90 I think). I always use spray wax buy hate the mess I end up making with it.
I've use synthetic gear oil in the past. which works great but can get dirty quick when off road. I would clean and let soak for about an hour. Lately I have soaking in hot paraffin wax and spray with a chain wax before taking a ride. between cleanings of the chain. I found that works the best for me and stays cleaner.
2004 Honda ST 1300
Old 10-26-2017, 01:45 PM   #5
dh   dh is offline
2013 SSR XF-250
Old 10-26-2017, 01:49 PM   #6
You will start getting a saw tooth look to the teeth. Check to make sure the chain is seated in the sprocket all the way around were it make contact. the chain shouldn't be bunching up anywhere.
2004 Honda ST 1300
Old 10-26-2017, 04:06 PM   #7
Ariel Red Hunter's Avatar
+1. My only addition to this is to check BOTH sprockets...ARH
Old 10-27-2017, 12:28 AM   #8
pete   pete is offline
pete's Avatar
i have had my TTR for 4 years & i'm on my 2nd set of sprockets & chain..
It is a dirt only bike...dirt/dust/mud/river crossing...
all I do is water blast it when I clean the bike . adjust it if needed & spray it with
castrol chain lube..
the XT660 I get 20,000km from chain & sprockets...
I use RK chains & either Yamaha or JT sprockets...
I usaly go though 2 front sprocket to a rear...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 10-27-2017, 01:47 AM   #9
dh   dh is offline
This is all really helpful. Looking at all of this I think my sprockets are fine and my chain is over tightened causing excessive noise. I estimate there is a hair under 1/2" of play in the chain right; I checked and adjusted this morning before riding and I think the chain became overly tight when I torqued the axle nut down.
2013 SSR XF-250
Old 10-27-2017, 07:40 AM   #10
Check the chain for play while you are sitting on it to make sure it is not getting tighter with a load on it.
2004 Honda ST 1300
