Advance timing for better performance zomgshen cg200
I've read that some people grind out mounting holes so they can advance timing. People say it adds a notiable difference. Couldn't find any instructions /guidense how to do this and how much to advance ect ect. Anybody have experience with this? Thx
Are you talking about advanceing the cam or ignition timing?
the thing with anything built on a prodution line things end up slightly diffrent to what the specs say they should be... Honda XR are around 2* retarded cam timing on what Honda intended them to be you could buy sloted cam sprockets.. you set the timing with a degree wheel on the crank... ..
#3 | |
I've thought about doing this myself. By advancing the timing you may lose some low end power but will increase top end. At the same time you will have to run a higher octane fuel to compensate for the higher timing. But the correct way to do this is to get a programmable CDI to that you can keep the time where it is now in the lower rpm and increase timing in the higher rpm range. Like this http://www.dansgaragetalk.com/topic/...-time-mapping/
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-23-2017 at 10:45 AM. |
Just be aware that advancing the ignition timing causes a rise in cylinder pressure. As Jerry mentioned, this increases the amount of heat in the chamber and often means you have to run a higher octane fuel.
Before you get too deep into this, I would suggest getting very familiar with the whole theory and terminology behind ignition timing. That said, here is the simple version. Your intake charge takes a fixed amount of time to ignite and burn. Because of this, it has to be ignited before the piston reaches Top Dead Center. This is why ignition timing is often listed as X degrees BTDC (Before Top Dead Center). If your engine currently has a base timing of 15 degrees BTDC, then to advance the timing means you are actually firing the spark plug sooner, so in this example lets say you advance it 2 degrees. Now your ignition timing is 17 degrees BTDC. Since the fuel is ignited even sooner before the piston is done reaching TDC on the compression stroke, it is fighting more pressure on it's way up, and the flame of the ignition is in the cylinder just a bit longer. All of this extra pressure and fire in the cylinder for a longer period of time causes an increase in heat, which means the plug and combustion chamber are hotter, thus at a certain point means you are more likely to run into pre ignition.
#6 | |
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 10-27-2017 at 07:06 PM. |
Advanced timing
I purchased one of those " racing cdi boxes" that did just that! It advanced the timing,,,while there was a small gain ,,,, it was NOT worth it. As it made the bashan harder to start an it definitely ran hotter. ,,was not worth it,
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
#8 | |
Without a doubt, I would not mess with advancing the timing or other performance mods without some sort of oil cooler to help keep engine temps in check. The stock engine already struggles with controlling heat as it is.
#9 | |
